The warts I see with the Yorkville Unity are the following:
1. Directivity which waistbands significantly. Danley has counteracted this in his Synergy designs by widening the outer portion of the horn.
2. Port holes that aren't shaped optimally. Can be reshaped to look more like Synergy ports.
3. Crossover is weak. Easy to fix.
The only thing not fixable on the U15 is the horn profile. It isn't the end of the world, but a bit of an issue for me. The good thing is that you are buying very good drivers for the money and it is principally the same as a Synergy design. The details are just a little different. Of course, it doesn't require the woodworking effort of a Synergy clone.
The other issue is that it is a relatively small horn for utilizing Unity/Synergy principles. IMO, the biggest benefit of the Synergy design in a home is the ability to maintain point source controlled directivity over a very wide frequency range. Is there any point in using a large format CD like a JBL/TAD on a horn that is only good down to 1000hz? I don't know of way besides Synergy/Unity to hold horizontal from 300hz-18khz. You could use a 2" horn to get pattern control down to 300hz, but it is ugly above 6khz and expensive. You could use a separate midhorn but that gives lobing issues and isn't point source. Coax gives point source over that range, but directivity is messy. Synergy is about as close to perfect that I can imagine. 36" wide LCRs holding pattern to ~300hz is what I want. Of course that isn't going to work in a living room and even Danley doesn't sell something like that because it isn't practical in pro.
-- my first real listen was pressing them into duty as sound reinforcement for my high school senior's Halloween party; providing high-quality noise for about 60 freaks dressed in costume in a rented basketball gymnasium. It was short notice as a family friend that is a DJ was going to do sound but got a better (better=paying
