just went to a couple of movies recently and the black levels were almost exactly the same as my home projecter(sharp xr 10x) a old computer projecter dlp 4x color wheel with 1024 x 768 resolution any way got me thinkin are we looking for the best blacks possible or somthing comparable to the average cinima if its the latter i think any dlp or lcd if far enough from screen will be fine as long as you can calibrate to 6500k gamma what do you think .
i know jvc is black level king at 3000 but if 1000 buys a experiance the same as theater why not plus if you make your home theater too good wont it ruin the cinima cause i still like the fun of going out with friends and if im anal about its quality then ill be missing out on what the average cinima goer gets out of the theater what do you think
I notice they also use bias lighting... but the bright blue halo is not the effect i'm after. I have in mind something like an evenly-lit frosted plexi or rear projection material wall in 10-30% gray, if active lighting at all. it certainly would making testing different values easy.
