AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How many watts for my deftech speakers
post #1 of 5
I have the definitive technology pro cinema 600
http://www.definitivetech.com/products/procinema-600-system
Here are the specs.
I listen to movies at a average volume and also medium to soft at night.
How many watts do i need to match these speakers and give the best sound at low volumes so i can still here details in audio
My living room is 19ft by 13ft but the ceiling is 2 floors up
post #2 of 5
Sorry ignore the last duplicate threads. There was a error while posting
post #3 of 5
Those speakers should be fairly easy to drive and on average will only be drawing < 5W/CH so most any AVR (eg. 50W+) will provide more than enough power.
post #4 of 5
How did you come up with 5watts per channel why do they say they can handle 150 watts?
post #5 of 5
Those speakers have an 88db efficiency rating which means if you're seated about 10' from them you will get roughly ...
1W = 78db
2W = 81db
4W = 84db (which is quite loud and generally louder than most folks listen at)
