AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › New Pemko automatic door bottom
post #1 of 2
Pemko looks to have a new acoustic automatic door bottom available http://pemko.com/index.cfm?event=updates.viewUpdate&updateId=40 Does anyone have an opinion on Pemko vs the Zero products for door sealing? I can get the Pemko stuff locally for much cheaper than Zero so would prefer that but would spend the extra if Zero is much better.
Door jambs are here http://pemko.com/index.cfm?startRow=1&event=products.productListing&searchName=Search+by+Category&openFilter=loadCategorySearch&ratingIds=&categoryId=899&subcategoryId=909&productMaterialId=&competitorId=&partCategoryIds= Was looking at the 379_R.
Edited by rob4321 - 11/4/12 at 5:31am
post #2 of 2
If it makes a difference zero's jamb weatherstripping have the ASTM E90 sound tested rating but the pemko ones don't. The pemko door bottom does have it though.
