Originally Posted by
zheka
Geddes is now talking about using decorrelation filters in lieu of his trademark multisub approach. More than one sub would still be required but location becomes less critical making it much more user friendly. It would be very interesting to see how it plays out.
From what I've read and discussed with Dr. Geddes, nothing's changed except the filters.
Placement is less critical when one has more subs. That's one reason I'm using 5 rather than 3 right now, and will be using 5 (in a slightly different configuration) when my the new mains cabinets I've commissioned are done (hopefully by the end of the year).
J_Palmer_Cass
Geddes uses bandpass subwoofers, so how much ULF bass (AKA sub 20 Hz bass) that is contributed by those speakers is an unknown.
No it's not. One can easily model his subs. They use commonly available drivers (B&C 12TBX100), and one can make reasonable inferences as to their relative cabinet volume and tuning based on their external dimensions.
Also, 4th order BP contribute below cutoff, because they're still monopoles (backwave trapped). My understanding, furthermore, is that he's
talked about a separate ULF sub, but never actually implemented it. Just the three B&C 12TBX100 based subs. But Perhaps I'm wrong about that.
But I believe Dr. Geddes' answer as to sub-20Hz bass is the same as mine: don't care. Besides, placement can't materially effect anything down there. It's just volume displacement and EQ.
DS-21
That is a subjective opinion. How do movies sound?
Don't know, and don't care. Movie sound is entirely irrelevant to me, as long as dialogue is audible at low volumes.
Besides, if some special effects dude's idea of what a bomb blast sounds like is 2dB quiet or 3dB hot, who cares?
It works fine on concert videos (Radiohead TKOL Live from the Basement, Adele at Royal Albert Hall, Zeppelin at the O2 Arena 2007, etc.) though.
DS-21
Still, that does not address how Geddes routes his bass as noted in your link
I don't understand what you mean by that.
J_Palmer_Cass
That's fine if you want speakers that are on the large size.
Yes, if one wants a 2-way it has to be "on the large side," because otherwise it won't be capable of the required output. A reasonable reading of my earlier post would appropriately limit the scope of my comments to
2-way speakers.
Multiway speakers allow different form-factors (assuming narrow directivity isn't a goal; width is the only way to get that).
The NHT speakers you showed were 3-ways, not 2-ways.
Likewise, I needed narrower speakers for aesthetic reasons, so my old 12" concentrics in 17" wide cabinets had to go. To get similar volume displacement (but even so, markedly lower efficiency, down from ~96dB/W/m to likely 87dB/W/m if I'm lucky) I had to move to a 3-way design: 5.5" concentric driver flanked by two 7" midwoofers. (Though it could be considered a 4-way design, given that the mains will sit on "stands" containing side-bottom-back firing 12-inch "flanking sub," a la NHT 3.3 and others. But that's separately powered from the tops)
Edited by DS-21 - 11/29/12 at 8:48am
