Super sweet assembly video! After watching that, it looks like I need to set up some type of video system and give it a try. Of course I don't know how to edit, so watching it would take about 8 hours!!
You really did a good job on that, very impressive. Is there an easy to learn video editing program out there that won't break the bank? Or should I just send you a pallet of flat packs with some free wood glue???
I noticed it looked like you were tapping in that final side panel towards the end. That's pretty normal during assembly when there's a double layer baffle that has to be fully recessed into the box. But you did a great job getting it all together.
By the way, if you look at the inner baffle, you'll notice that the waveguide cut out is about 1/4" narrower on the sides. That was done on purpose because the inner baffle isn't as wide as the outer baffle. So when the waveguide hole is cut, it's fairly close to the edge, so I had them bring it in a little on the sides to beef it up.
