AVS › AVS Forum › Audio › Soundbars › Mounting a Vizio VSB200 to Panasonic VIERA TC-L42E3
post #1 of 2
Yes I just bought the Vizio VSB200 soundbar and it is on it's way. I would like to mount it above my TV which is a Panasonic VIERA TC-L42E3. I just looked at the back of my TV and I don't see any place to use the Sewell Universal Soundbar Bracket that I am looking at on Amazon.com. Anyway know if it is possible to mount that bracket to my TV and soundbar? Thanks.
post #2 of 2
These universal brackets typically attach to the VESA mount holes on the back of yourTV. If your TV is on its pedestal, the holes probably have plugs in them so you might not have noticed them. I see several reviews on both Amazon and Sewell sites where people have used the brackets with Vizio soundbars and Panny TVs.
  Back to Forum: Soundbars
