Pardon my overstepping and pretending to help you all design - you're doing a great job. I just want to suggest this (pardon the crudeness) design for the multiple soffit heights.
I thought the pictures would definitely provoke the thought of some people here and they would come up with some ideas for the transition ! Keep em coming!
Interesting I will take a look at that tomorrow. Keep in mind that the faces are 4 1/5 inches high and the height difference is less than that, a considerable overlap not evident in the picture. But that concept will solve another problem I haven't discussed
For real, I would keep it simple and tie it in together. You won't lose any headroom, and it will keep it smooth and together on the wall. I know you mentioned its not a total overlap, but I'm guessing you could rip the boards to fit and then cut your drywall to hide it all.
Also, It looks like your column is going to fit right there in that little jog. I wouldn't want it to busy right there to distract from the column work.
Another idea, would be if you could move your column just that last three inches to the left, it would be a clean break and you wouldn't need to transition the soffits.
Could you maybe continue this pattern to the back of the room creating a sort of repeated stepped effect? Bring it out from the wall just far enough to repeat the curve in towards the wall (3 or 4", maybe?).
Cannot move the Column because it was already far too left than needed and if we shift it more it would bring the side surrounds ahead of the seating position.
I like the Idea but it will make the area of the room in the back which is already short and small more smaller and also the soffit will then interfere with my second pair of side surround speaker height or interfere with the drivers. My surrounds are tall and long.
Sorry no Pics today. It was a day of small tasks including sealing up holes in the wall from electrical, relocating some wires to the proper location (new holes and some fishing) Running electrical inside the soffit for three zones of cans and three zones of rope. Testing the later with a continuity tester because we don't want to open up the soffit once the bottoms go up. And a run to pick up a bunch of electrical supplies. Securing and sealing HVAC duct penetrations.
Somewhere in there I had a meatball sub on whole wheat from Subway. Toasted.
Wow... this looks amazing. Big, you never fail to amaze. I really enjoy watching these builds come together. Definately Subb'd. Hope you guys all have a great Thanksgiving.
Big, what size cans are you installing and where did you find the hole saw? I am installing 4" lights from Lowes, but I can't find a hole saw that matches the size needed for my lights. It is one thing to hand cut a hole in drywall, but it is anothre thing to try and cut a clean hole in MDF by hand.
EDIT:
Also, are you planning to use rope lights around the soffits?
it is a 3.875 hole saw, I think I ordered it from Amazon. It's funny I think I've used three different cans from Lowes and they never seem to sell the size hole saw that fits their lights.
On this project I'm using the 4 inch cans with the connection box on the side, they are shorter than the 3 inch can which has the connections on the top. AND the connection box is HUGE in comparison. The soffits are 5 1/4 tall.
Yes on rope, still need to bang up lip on ethe front edge of the MDF to create a channel for the rope. Something about 2 inches tall.
For the record on the other three walls I cut all the holes when the MDF was on the ground, I can only take overhead cutting long enough for one photo op. Edited by BIGmouthinDC - 11/22/12 at 6:50pm
Plenty of work done today, Caulking of gaps and holes with acoustic caulk. Wiring for cans lights, rope lights, smoke detector, insulation with ecobatt and insulshield, extending supplies and returns and finishing the face of soffits. Hoisting the MDF was a pain! As usual Big worked non stop and with full force without breaking a sweat
Hey Big - looked for the hole saw on Amazon but couldn't find it. Do you have the make and model?
