AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Fall Frenzy, Curve Frenzy, Man of Steel theater (You pick) - BIGmouthinDC hits the road again - destination Columbus, Indiana
Fall Frenzy, Curve Frenzy, Man of Steel theater (You pick) - BIGmouthinDC hits the road again -... - Page 4
post #91 of 983
Nice house! How far are you located from The Arrowhead Project?
Originally Posted by vikgrao View Post
Your Welcome. Big gave me a couple of simple things to do before he left. One of them was to prime the theater room. Well? i got a little busy with other things and yesterday i spent few hours vacuuming all the walls and ceiling to get of the drywall dust (was a real pain!) and i just gave up today and got a person to do it for me for a unbelievable unheard of price!. Great thing is he is also a artist and graphic designer.
Hope Big enjoyed the warm weather where he went, since after he left a STRANGE FOG rolled in right in the middle of the day and almost ate up his white van parked outside, after this the weather here changed to crazy cold! Right now as i post the priming is being done.
post #92 of 983
Thanks Nebrunner, The last picture says it all, that is exactly what happened and is still going on!. I may be around 20 hours drive from the Arrowhead project but only 90 minutes from Waverley Hills Sanatorium!
http://therealwaverlyhills.com/
http://www.youtube.com/watch?v=_bbn0GssDRQ&feature=relmfu
Edited by vikgrao - 11/13/12 at 6:07pm
post #93 of 983
What are the important signal processing elements, and what hardware are you going with?
I am going with the Denon 4520CI receiver. The signal processing Shawn said that i need to implement along with it is a couple of QSC Audio DSP 322UA and a Audio Control Savoy G3 amplifier for the surrounds. I am yet to make a decision about them still.
Edited by vikgrao - 11/13/12 at 6:06pm
post #94 of 983
Inquiring minds want to know!
post #95 of 983
post #96 of 983
Sorry -- my post fell out of sequence. I was interested in your EQ and amplifier choices.
post #97 of 983
...a couple of QSC Audio DSP 322UA...
Well, I can't imagine you could find too many units more full-featured, but I sure can't see why you would need more than one. Of course, I don't even know where to shop for similar items, so what do I know? Thanks for filling me in.
post #98 of 983
The reason the system would require two DSP's is the number of outputs required. In VIK's case, he has 9 outputs at a minimum maybe more depending on the number of subwoofers. Each DSP unit has a maximum of 8 outputs.
post #99 of 983
Ahh, yes. The extra subwoofers. I always imagine that sort of DSP used only for full-range channels, with devoted DSP for subs. Clearly the all-in-one is the cleaner choice. Thanks for clarifying Shawn.
post #100 of 983
You're welcome! Bang for the buck, you cannot beat the QSC 322ua's. You would be very hard pressed to find units anywhere near as capable as those for the price.
post #101 of 983
Edited by vikgrao - 11/14/12 at 9:07pm
post #102 of 983
Wednesday Update:
Edited by BIGmouthinDC - 11/15/12 at 6:59pm
post #103 of 983
Thursday:
One of 22 sheets (Vik helped with most of them)
Three layers with Green Glue, Vik manned the gun I cut the pieces to fit.
Lip cut twice, first layer with 1/2 inch overhang, second with 2 1/2 inch overhang.
post #104 of 983
post #105 of 983
Dear BigMouthinDC,
Stanley Panel Carry
$6.97 at the Depot.
Sincerely,
Your Spine
post #106 of 983
I actually have a yellow one but the Sheets were stacked in my van against the cabinet where I think it is stored. No Pain no gain.
Edited by BIGmouthinDC - 11/16/12 at 2:53am
post #107 of 983
Originally Posted by vanice View Post
Yep he is back and i did very little to help Big today and most of the time he alone powered through everything. Hopefully i can be more useful tomorrow smile.gif
post #108 of 983
Subscribed. A great build thread for sure!! Love seeing designs from Shawn (he calibrated my Kuro) and Dennis. They are some of the best. Vikgrao have you decided on a projector yet?
post #109 of 983
Thanks! The design is actually of a French theater I saw on the web but Dennis did design the raiser. Shawn and Dennis also did the room layout and acoustics. BigmouthinDC (Jeff) further tweaked the design and started building and turning my room into reality and making my dream come true. They are all Gurus on the forum and highly recommend.
I am contemplating between the EPSON 6020 or Sony HW50ES whichever lights up my 140" centerstage better for 3d and 2d. This will be temporary untill I am ready to upgrade to a better one.
Edited by vikgrao - 11/16/12 at 5:07am
post #110 of 983
Cool man. Oh ya that's right I remember you saying earlier how you were inspired by a French theater. You will definitely be taken care of by that all-star group of guys you hired. Your equipment list is killer too. I can tell u definitely did all your homework and then some. I hear ya on the projector. I just purchased a BenQ W7000 to get me by until I can save and get a really high end model.
post #111 of 983
Worked continued on the curvy riser and stage. All decking is done, the steps were made. Everything three layers but you only see two in the pictures. the small step was typically over engineered but it is solid. We also attached a lip under the outer edge to conceal rope light tested it and it worked Pics tomorrow on that concept. We go up off our knees and decided to pull in the speaker wires for the front array, We pulled both balanced connections and regular speaker wire. Redundant but future proof. I wanted to pull the wires now before we start working on the soffits and walls because I didn't have a hand in installing the conduit or drywall and if there was a problem requiring wall/ceiling surgery I wanted to do that early in the process.
Reinforcements arrived to help with the wiring.
Tomorrow we start on the soffits.
post #112 of 983
Which way does the door swing?
post #113 of 983
Design called for swinging along the curvature of the step.
post #114 of 983
Deviation from plan, not ideal but reality. Theater owner/builder wants an out-swing, right handed door.
With two inches of Quest panels on walls and the door, swinging in would have been very interesting.and required a very wide throw hinge. Door to receive two layers of 1/2 inch MDF + GG and will have an electronic keypad lock. It will have 5 hinges.
Edited by BIGmouthinDC - 11/17/12 at 1:09am
post #115 of 983
Nice work...you guys seem to be rolling along. Man I can't wait to get started!
B2
post #116 of 983
Oh ok, was gonna say, doesnt look like there was room for a door after the top layers to the steps. So just 1 door swinging into adjacent room, gotcha.
post #117 of 983
This thread has turned into a swingers thread....
post #118 of 983
Swingers? Great. I'll be in Indy Monday/Tuesday. smile.gif
post #119 of 983
Come on down! Just south of the city. We will be working on the soffits.
post #120 of 983
Hey, you have the theater seating without armrests.
