AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › LG 47LM4600
LG 47LM4600 - Page 6
post #151 of 305
Originally Posted by AdrianO8 View Post
So let me clear the air over LG's Trumotion 120hz and why it doesn't look like other brands such as my friend's Samsung HDTV that has120hz.
The air has been cleared for many months now about what LG (and other brands did this year in certain models) when outside testing sites began to notice a fowl stink in the air of false claims. The REASON it looks different than other TRUE 120Hz sets is again, because it is NOT 120Hz.. No equivocation, it's literally black & white. It's operating at 60Hz period!.
I had a chat session with an LG support rep and they informed me that the LG panels for 2012 all use a specific Backlight method. I forget what they called it, but pretty much what the TV does is throw a dark frame in between the picture which causes it to not have such a "soap opera" effect.
"LGs spokesperson told us they are using a technique called “Black Frame Insertion.” Their claim: in between the 60 active images, LG shuts off the LEDs sequentially from top to bottom. This shortens the time the LCD panel is illuminated in section by section thereby reducing motion blur.
60 Hz LCDs sample a frame and keep the same image about 16.67 ms. This allows little time for the pixels to move to create the next frame. The panel holds the image and then repositions the pixels quickly for the next frame. Our eyes and brains are programmed for seeing continuous motion, not sample and hold, change and repeat. The result is we see smear know as motion blur.
A proven technique to reduce motion blur is to sequentially darken the image from top to bottom, making that portion of the frame black instead of an illuminated still image. This reduces the visible hold time and the brain perceives sharper motion. This is the technique LG claimed to use in the 6700.
Our Test Results
To confirm LG’s backlight scanning claim we used a video camera recording at 480 Hz (four times the 120 Hz claimed refresh rate). We then chose a slow-motion playback of 15fps to illustrate the LED shut off sequence. As you can clearly see in the video, the 55LM6700 does not employ top to bottom scanning. Instead, it shuts off the LEDs at the sides, then the center and repeats the sequence."
-HDGURU article was written about the 6700 but it applies to the lower tiers of LG. / follow the links I posted above if you want to watch the video they speak of.
So to sum up so far... LG made a claim on their box of 120Hz Tru-motion. What they gave instead was a smoothing method that they because of the design of the LEDs on these TVs there are not actually able to implement a top to bottom black frame (again see the video) and ALL THAT IS STILL BESIDES THE POINT I don't want to lose sight of the FACT that it's nothing remotely close to actual 120Hz frame rate. And what they do CLAIM to offer is not done correctly, because of the design of these TV's LED array; they couldn't actually implemented the top to bottom dark frame. I'm all for innovation and new ways of doing things if it's a step forward but this is an incorrectly implements step backwards resulting in a poorer product that they claimed was still at the previous years higher standard!
So last year's LG 3D models all use a method where they throw in a regular picture frame that's lit instead of dark in between the picture. I asked the rep what passive 3D TV's didn't have this method and she informed me the panels from 2012 all use this "Dark Frame" method,...
Prior to these 2012 models:
"120 Hz refresh HDTVs employ a circuit called Motion Estimation/Motion Compensation (ME/MC). These chips analyze consecutive original frames then create and insert synthesized frames between the original frames. This results in better motion resolution. To date, using the industry accepted FPD reference disc, we’ve found every 60 Hz LCD we’ve tested has about 320 lines of resolution. With ME/MC circuit engaged on a ME/MC circuit-equipped 120 Hz HDTV, the motion resolution increases to 600 lines.
All 60 Hz HDTVs use a technique called 3-2 pulldown, which converts the 24 original frames to 60 Hz by displaying the same frame three times then the next frame twice, then the next one three times etc. During pans, this uneven cadence creates a jerkiness called judder. We use a judder test sequence on the Marvell Qdeo test disc to test whether TVs created smooth motion with 24 frame sources.
We asked LG if any of its 2012 HDTVs with a factory specification of 120Hz refresh rate employ an ME/MC chip. The response was no. LGs spokesperson told us they are using a technique called “Black Frame Insertion.” ...
Contrary to LG’s claim, this technique had no effect at all on the TVs motion resolution. We tried Cinema and Expert picture modes and observed the same results, 320 lines of motion resolution, the same motion resolution as every make and model 60 Hz LED and LCD we’ve tested to date. Furthermore, there was always judder present, again confirming 3:2 pulldown as in a 60 Hz display. We were able to shut off the blinking LEDs by placing the TV in its “Game” mode, and found the motion blur results were the same as when the lights were blinking, only 320 lines of motion resolution .
We presented our findings to LG. They confirmed the LEDs in the 55LM6700 are only mounted at the bottom of the screen, making a vertical scan impossible as they would have to be mounted under on the left and right edges). LG provided its own 24fps judder test material; however, we saw the same judder as observed using our Qdeo test disc.
Based on our findings we asked how they could call this HDTV a 120 Hz model. Their response: “With respect to these advanced testing methods, the results illustrated are an overly magnified representation of the average user experience; what really matters is what consumers can see with their own two eyes.”
LG continues to post on its website, and dealer descriptions, simulated photos showing a significant reduction of motion blur with its claimed “TruMotion 120Hz” refresh. (photo below) [See the article linked in my post, a few above, to see the images]
We find these claims incorrect and unsupportable based on the FPD motion resolution tests used by HD Guru and other major well-respected TV reviewers. Our high-speed camera clearly shows LGs scanning claim to be incorrect as well. This TV is a 60 Hz LED LCD. All tests yield no motion blur reduction compared to any 60Hz TV"
- HDGuru (Link posted several posts above)
There is NO comparison between say watching a High Definition fast action scene like a Blu-ray movie or sports event in 60Hz with the Black frame insertion software based display & TRUE 120HZ ME/MC chip where the user can dial in the amount of judder correction to their liking. The 120Hz allows the 24fps and 30fps refresh without the interpolation 3:2 pulldown of 60Hz causing in judder effect.
...but that panels from2011 don't use the "Dark Frame" method. Unfortunately all panels from 2011 are active 3D TV's which is not what I want.
This is absolutely incorrect. LG Plasma used Active shutter glasses, but LG LED/LCD used passive 3D just like they do this year, the difference being that those having 120Hz technology actually had it installed. It wasn't a lie!
I then asked if she had any news on 2013 panels and if they also indeed have this "Dark Frame" feature and she was unable to give me the information because they were only in the pre-sale status. Now I apologize that I don't remember the specific name for this "Dark Frame" method but the rep was very quick to answer my question and if they weren't closed right now I would just pop in a chat session to ask again.
I hope this helps everyone and besides the 120hz feature I absolutely love my LG TV. I got it at a fantastic price of $601 at Fry's which is a steal especially since I received free shipping.
The problem is that LG made a mistake either accidentally or deliberately to advertise a set as having a capability 120Hz Tru-Motion. The reason I can believe it was an accident is because they literally gave test samples of these TVs to sites whose practically sole mission is to dissect TVs; so if they were deliberately trying to pull a fast one they picked the wrong line of products to do it with. Further the last of 120Hz listing on foreign websites?!? I believe either way.
HOWEVER, giving LG the benefit of the doubt for the mistakes of having it plastered all over the U.S. Boxes and over the U.S. Website when the "Mistake" was pointed out; the response was (posted above): "With respect to these advanced testing methods, the results illustrated are an overly magnified representation of the average user experience; what really matters is what consumers can see with their own two eyes." - Translation most consumers don't / won't know the difference --> a statement that I and others who like to get what they pay for and know how to dial in a TV find to be were they transition from having made a possible "mistake" into willful knowledge of the lie/issue and using a false equivalency argument to say it's basically the same as 120Hz Tru-Motion which is Damn Lie!
Edited by DA1745 - 1/25/13 at 8:24pm
post #152 of 305
WOW thank you so much for this explanation! This is exactly what i was looking for and you sir have provided me with it. Everything in great detail. Time to return this TV and shop around again.
post #153 of 305
Can you get a true 120Hz TV for the price these LG sets are going for? I did see an open box LG at BestBuy for $600 that I think had it, but everything else I looked at there was alot more expensive unless I went with a 42" or 40" and those were still a little more expensive than this LG set.
post #154 of 305
I finally got my set in it's permanent position. At least I'm seeing much less crosstalk than before since my eye height is just below center of the screen. Although there is still little bit of cross-talk but nowhere close to what is was before.. What I find odd is the passive 3D from this set is more fatiguing to my eyes than the active 3D from my DLP. Maybe I just need to get used to it. But I still like it enough that I am definitely keeping the set.
post #155 of 305
I'm surprised that you are still seeing some crosstalk. I have seen it on my set on only one occasion. You said that you are using the latest firmware?
post #156 of 305
I'm also very surprised that you are finding the passive 3D to be more fatiguing than your active DLP. Regarding your crosstalk problem, there was someone in an LW series thread last year that had a similar issue. It turns out they had one bad pair of glasses. Have you tried other pairs?
Edited by Navigationroad - 1/27/13 at 4:15am
post #157 of 305
yesterday I bought this tv from frys. When I try to upgrade the firmware it said current firmware is of higher version . Yes my tv firmware version is VERSION 03.40.09. Is there a way to check firmware version ?
post #158 of 305
Click "Settings" from Remote and then press Red Button with White Dot (Bottom Left of Remote), Click Software Update and popup window will appear "Current Version xxxx".
With that said, my current version software is 03.02.67. I clicked Check Update Version and it's telling me none. Can i update via network or do I have to go to LG website and download from there?
Sorry if this has been answered previously.
post #159 of 305
Yes, I updated it to 03.40.08.
Although I finally realized what is different in the menu. I see no way to turn off the 3D nag screen whenever it detects a 3D signal. Or am I missing it somewhere? It's annoying that the screen comes up and doesn't disappear on it's own. I have to hit "OK" on the remote to get rid of it. I already know I'm watching 3D, I don't need to be reminded of it everytime I start a title in 3D.
Yes, I've tried the two pairs of glasses from the one box I opened. The results are identical from each one. The cross-talk is greatly reduced where I'm viewing the TV, but I still see it slightly in some scenes. On my DLP set, I specifically went looking for it on a bunch of titles, and always saw zero cross-talk from it. But I can also see the reduced resolution from the TV as well when viewing any text, even if I go nine feet back.
I had to download it from the website. Mine came with the same version as you.
http://www.lg.com/us/support-product/lg-47LM4600
Edited by aaronwt - 1/27/13 at 10:33am
post #160 of 305
thanks. you need to download from lg website.
post #161 of 305
I appreciate the response. Just downloaded the software update from LG site.
Any issues exprienced with the Software update or is it good to go?
post #162 of 305
The only thing I see is no way to disable the 3D nag screen.
post #163 of 305
i baught this tv 1 week ago . its amazing but i have one problem when i play 3d movie from usb the sound start for 3 minutes then it disappear . i have to switch off tv to come again .
anybody can solve this problem?
post #164 of 305
Might be the type of media file u are playing. Like some movies I have if they are MKV the video might play but no sound. Also u can try and play with the Audio chanel I think it is in video setting.
post #165 of 305
I havent upgraded to latest firmware cause I dont see any benefits yet.
I just wanted to share with u guys something I found while doing 2D to 3D conversion. I used to think it sucked and the depth 3D setting wouldn't change anything. Then I change the 3D angle to the right side might be the same to the left side and it makes the 3D look amazing.
so when u do the conversion play with the 3d angle viewing.
After reading all the post on this TV I still dont know if 120hZ to get the soap opera look can still be added by software update.
post #166 of 305
If it can be added I sure hope we will be able to tun it off or at least have it on a very low setting. The soap opera look is the last thing I want my movies to look like.
post #167 of 305
2d to 3d conversion works fantastically on Frankenweinie. Something about black and white I guess...
post #168 of 305
Unfortunately, my TV is not turning on. I bought it just 6 weeks ago and it's dead now. I tried all ways - taking out the power plug, etc...When I manually press the power button, I see the LG logo and then it automatically shuts off. Should I try something else or just return?
post #169 of 305
Do you guys think we have got the point to SUE LG now?
post #170 of 305
^^^If LG had ever claimed it's sets had a 120hz refresh rate you might, but they don't. Instead they say "tru-motion 120", just as Samsung uses "Clear Motion Rate" to fudge their numbers. I have a "Tru Motion 120" set. The box claims it improves motion. On my model it's adustable and works as advertised--reduces judder on horizontal pans. It won't do frame interpolation. I did my research ahead of time and knew what I was getting. I did not want frame interpolation so I'm happy.
Sue away if you want--I'm not saying their hype wasn't confusing, but so is Samsungs CMR and Sony's "Motionflow 480" so hit them too.
While you're at it hit Samsung for "Micro dimming (plus/etc) which doesn't actually dim any leds, as well as the ridiculous contrast ratio claims and the plasma mfgs. "600hz" claim which fools people into thinking they have 600 frames per second rather than 600hz subfield drive, a completely different thing.
It's about time somebody forced the tv industry to quit all the deceptive hype. Auto companies aren't allowed to make up their own hp and mpg numbers, why shouldn't tv mfgs be held to the same standard in the interest of consumer protection.
Edited by Steve S - 2/1/13 at 10:01am
post #171 of 305
Actually it says "TruMotion 120Hz" on the box and this image is straight off of their website: http://puu.sh/1VU4N
Doesn't say "Trumotion" anything only "120Hz"
Even "response time" listed in their spec sheet is "120Hz".
I was even aware of TV companies pulling **** like this, so I double checked and made sure it was 120hz before I bought it.... Then I found out I've been lied to.
In my non-professional opinion a class action suit would be a piece of cake.
post #172 of 305
where and how can we sign a petition from LG? i get lied and i want my money back!
post #173 of 305
If the LG 47LM4600 DOES support ARC, which I'm beginning to think it DOESN'T, I'm certainly having trouble finding it or getting it set up. Any assistance on this would be greatly appreciated before I end up taking this TV back to Best Buy.
post #174 of 305
is this supported by tridef DDD in playing PC 3D games?
post #175 of 305
So just got my 47LM4600 from tiger direct. It was 579.99, couldn't say no.
Just curious though. Will DD5.1 pass through the optical of the TV? Right now I have my direct tv cable box connected directly to my HT system (LG BH6720S) via HDMI and optical for sound.
Good TV so far. Picture seems really nice and the features are insane. I know this isn't a smart tv, but it's the smartest dumb tv ever haha.
post #176 of 305
Yes, it will.
post #177 of 305
That's even lower than the price they had last week when I had BestBuy do a price match with Tiger Direct. I think this TV is a great deal for around $600.
post #178 of 305
Let's make it happen! I'm quite angry about it personally... I would have paid more for a true 120hz TV... They claimed all over that it is a 120hz TV! I waited for awhile to replace my 60hz Samsung and debated for some time and decided this was the year I would do it. Was excited to see this TV, but now EXTREMELY disappointed that we've been fooled. Everyone buying one of these has been fooled!!
Doesn't look any better than my 60hz TV... We should build a 4cyl car and then sell it to LG as a v8..! "oh, well we thought the ave consumer wouldn't know..."
post #179 of 305
Originally Posted by takwai View Post
Does this tv support ARC? I can't find anything about it in the manual.
Originally Posted by thund3rcat View Post
It absolutely does.
Audio Return Channel, it basically lets you use your TV to pass the signal to the receiver. Plug all your sources with hdmi into the TV, run a single optical audio cable to the receiver and voila, switch to the optical audio cable input on your receiver, now all your hdmi sources has surround system audio.
Originally Posted by drwzer View Post
As far as I can tell this tv has no ARC.
Originally Posted by bdanser View Post
Not a good researcher, are you? This TV does in fact have ARC. Stop spreading misinformation.
Well, I can only go by my tv and it is not returning any audio to the receiver through the hdmi. I have to use the optical cable. Not a big deal since I run all my audio and Video to the receiver then to the tv but if I plug a USB key into tv then only audio from tv speakers. Prove me wrong. Lol
Originally Posted by fatboypup View Post
maybe your cables or receiver dont support ARC but the TV does
I'm wrong. This set has no ARC. My HT processor was auto-sensing the digital audio port even though it said HDMI. My bad.
Originally Posted by dydlee View Post
I second that assessment. Does not work with ARC with HTSL-50 soundbar system.
Also, this LG TV does not have analog outputs as a workaround, only a single optical out.
I just took delivery of my new 47LM4600, and I'm getting ready to start setting everything up. I'm wondering if this TV does support ARC, or not? There seems to be a difference of opinions here. I just got off of Live Chat with LG, and they state that this model does NOT support ARC? Can anyone confirm or deny?
post #180 of 305
has anyone verfied the quality of components in this sucker? I know it was a tv specifically made for black friday so I was a bit reticent about buying one back then (and we all know how often black friday tv's are crap more often than not). But thinking about returning my VIzio M3D550KD to Costco and picking up the 55LM4600 because of the horrible flash lighting and light bleed on the vizio.
Edited by wormraper - 2/8/13 at 5:25am
