AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Logitech Support (Harmony): Refuses to fix their database with codes for everyone unless I pay $30
post #1 of 5
Stunning:
My logitech warantee is over - for over 2 years. However, it is clear that their "Sharp elite 70" codes are not all correct. A mix of Pioneer Elite codes adn Sharp codes are needed. Sharp has provided us with the correct codes.
Long story short: Logitech will not "fix" this for everyone unless I pay $30 for paid tech support. If under warantee, they will "upload" the correct codes ONLY to my account.
Why is this in their interest? I am simply bafffled. I tried to be nice but this is infuriating. So If i go out, buy a new remote tehy will only fix the discrete codes for ME but not for everyone (they have been fixing it for people under their 90 day warantee)
Wow.
Anyway, beware. If you have better luck than me let me know how.
Best
sjc
post #2 of 5
Buy a new remote, get the new codes, and return it. Hehe
post #3 of 5
Suggestions that are as easy and well done as the Logitech software? I would love to just hack the damn database and add my own hex codes. Arg
post #4 of 5
You need to take this over to the Remotes forum. You'll probably get better help there.
post #5 of 5
I apoloize. I thought I put this under the Elite sub forum. My bad.... I should know better
