AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Where to find a decent or good SPL meter
post #1 of 6
Hey guys, where can you get a pretty decent (for a good price) SPL Meter? Or which is the recommended SPL meter that most people use and recommend?
post #2 of 6
Radioshack you have two types digital or analog.
post #3 of 6
A lot of folks myself included use Radio Shack. You can google feedback.
http://www.radioshack.com/product/index.jsp?productId=12680845
Rick
post #4 of 6
Rat shack is fine option for HT setup under $50. If you are interested in spending over $5k, I can give you several more ideas that are ideal for fine-tuning room correction.
post #5 of 6
Galaxy CM140 is well regarded, and somewhat standard at the high end of reasonable. They're great, and much nicer to use than the Radio Shack in my experience.
post #6 of 6
Thanks for the input guys. 5k is just a tad over my budget for the SPL meter. I will be spending my 5K on speaker wire!! eek.gif
