AVS › AVS Forum › Video Components › Home Theater Computers › HTPC and Directv
HTPC and Directv
post #1 of 5
I used the assassins guide built my HTPC and it works great. Is there a solution for recording HD directv from an HD24 that anyone is using? I have seen so much conflicting info it would be nice is someone actually has one that works.
HD video with matching 5.1 signal.
post #2 of 5
All you need is the Hauppage HD-PVR or Colossus and an IR blaster and you should be able to record from it with no problem.
post #3 of 5
Half right, the best choice is the HDPVR or Colossus (component/HDMI). The IR blaster is not needed as you can get network tuning going easily. This is my setup.....2 Colossus cards, 2 directv receivers, and network tuning.
post #4 of 5
What network tuning do you use?
post #5 of 5
Is there any advantage between the 2 that would make one better than the other? Also is the software with it good enough to edit the commercials out?
Also there seem to be a couple of models
1212
1445
The HD-PVR2 is at BestBuy, that one any good?
The HD PVR doesnt use an HDMI cable, does it matter? Would prefer to use the HDMI for a single cable solution. Then I can make use of the 5.1 signal.
Edited by Dr_Mark - 11/7/12 at 9:27am
