Hi,
Anyone know a way to take out all the wrinkles on the pull down screen?
I have a pull down screen but the bottom of the screen starting to show wrinkles. Can you take an iron and put it on warm but NOT hot and iron all the wrinkles out? I am talking about the iron you use to iron your clothes.
I am thinking there is not much you can do about it since it is a pull down screen.
Thanks for any advice!!
