Lighting Underneath Seat
post #1 of 6
Hi,
What type of lighting do I need to put underneath my couch? I was watching a video and saw a really cool blue lighting underneath the seats. The color does not have to be blue, it can be red, orange, white, yellow, purple, pink, etc. Can I get something like that at Home Depot?
Here is the youtube video about home theater building:
http://www.youtube.com/watch?v=MrJvzSGV9T8&feature=related
Thanks for any advice!!
post #2 of 6
Rope light would be my guess?
post #3 of 6
LED's or cold cathodes would work great. I recommend LED's. http://www.elementalled.com/shop-by-item/strip-lights.html
post #4 of 6
Thanks you guys!
I will give it a try.
post #5 of 6
Check out Lowes, http://www.lowes.com/pd_696-24994-HTP904E_0__?productId=3316942&Ntt=led&pl=1&currentURL=%3FNtt%3Dled&facetInfo=
Cryon LED lighting systems. I used these behind an acoustic transparent screen to show the speakers behind. Turned out pretty cool.
post #6 of 6
barlighting.com
i've used them for behind screen and actual bar lighting. great and easy to use.
