Originally Posted by
murphybucket
Did i brick my H.k. 3600 I Upgraded last night and I go to turn it on and i get a power light and that is it. It's still warranty but will they fix it or blame me? Is thereareset i can do. Anything i can't be without it
If you upgraded equipment in warranty using the manufacturer's firmware upgrade and procedures, then I would think that it is still in warranty.
The only kind of firmware upgrade that would take a piece of equipment out of warranty, would be the third party firmware upgrades that people are applying to their music players. Some of these have bricked a number of players and since it is not vendor software that bricked the machine, its not his problem.
My first attempt to recover from the situation would be to try to run the firmware upgrade again using a clean flash drive and download. Usually these upgrades are accomplished by loading a USB flash drive with downloaded files, and then doing a cold start of the piece of hardware to be upgraded. I'd redo the whole procedure from scratch including fresh downloads. In most cases the piece of equipment need not be fully operational to perform the firmware upgrade.
