AVS › AVS Forum › Display Devices › CRT Projectors › ECP 4001 Green wont project??
post #1 of 5
Hello, I recently got this projector and everything seems to be fine, all the colors work in the menues but when I hook it up to me computer the green tube does not project the image??? any help please! edit-4101
Edited by Theodore7 - 11/5/12 at 7:51pm
post #2 of 5
Your RGB input board may be bad, but I'd suspect your input cable. REverse the green and red BNC cables and make sure your green cable works. I've got lots of RGB input cards if you need another one.
post #3 of 5
I got it, the connection if the green bnc cord has a little play. That was it, took me hours to figure it out. But so worth it. Thank you Curt!
post #4 of 5
I've run into another problem.. The center of the green gun will no focus, The direct center will but I little bit up and it refuses, no matter what I do. Is this a resistor issue on the Focus board?
post #5 of 5
No, it sounds like you most likely have fungus. There is one global focus control per tube. If the edges are in focus, the centre should be as well. Fungus however will make it look like it's a mile out:
http://curtpalme.com/Fungus_Removal1.shtm
  Back to Forum: CRT Projectors
