I just got a free Toshiba 62HM196 fixed and man what a super picture. I am amazed at the clarity and depth of the display. I have found as this is my first venture into DLP that it does dispense alot of heat from the lamp area. All the fans are working as I had everything torn apart. My installation is in a corner so there is alot of space behind the TV. I have placed a small circular 110V fan on the floor pointed up to the lamp exhaust area to help push the hot air away faster. Has anyone else with a DLP used an extra fan to help that area stay cool and if so how did you position your fan?? Maybe I should have it blowing into the lamp area but thought I would ask those with more experience. I am certain that the better the lamp is kept cool the longer its life will be. Thanks for any suggestions.
AVS › AVS Forum › Display Devices › Rear Projection Units › Anyone using an extra fan to help cool their DLP'S??
AVS Top Picks
