AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Vizio M650VSE Owners Thread!
Official Vizio M650VSE Owners Thread! - Page 23
post #661 of 698
Originally Posted by Datagg View Post
Hello. Is there an official thread for the M3D651SV. I looked, didn't see one. We just bought this the other day. Looks great, yet there are a few shows that just dont look as they should. Kinda like what i would explain as color morphing. Seems to happen with greens more than anything. We have DTV with a HR34. All components running into my Yamaha RX1000, including, HR34, PS3, 360, Blue Ray player. All sent back to M3D651SV via HDMI 3D Monster cable (needed longer one to reach side of the TV). Anyways, messed with some settings here and there, yet really didn't see much of a change. I read this entire thread and its all about the 650 it appears, hence why im looking for an official on the 651SV to see what others have done. Oh and using ARC, which thus far is working good.
Thanks Guys for your time
The Official 651 thread is here: http://www.avsforum.com/t/1439520/official-vizio-m3d651sv-owners-thread.
A few folks posted some settings you can try. One setting I think that helps is the local dimming, but i'm not sure exactly what you're referring to. In any case you might check the official thread for some settings. I also used the 709 HD patterns from the calibration forum here to do seom adjustsments. Though if you have some other HD calibration blurays I'm sure they work as well.
Rick
post #662 of 698
Rick
Thanks Rick.... To try to explain it better, I would say like a blocky look. Big squares. This don't happen with say a blue ray, or even from the ps3 or xbox... It mostly occurs from my HR34. Gonna try to go from HR34 direct to the TV see if that helps. I would bet though its the DTV box and its buggy design. Thanks again.
post #663 of 698
This TV kills me. I spent a lot of time reading through this thread, reviews on line, looking at the TV and finally decided to buy it. I don't have banding issues, no dead pixels, and for 85% of the time, the picture is very nice for the most part - vibrant with accurate colors (by the way, I'm running straight HDMI, and my sound is provided via a DENON receiver, not the TV). For animation, this TV is top notch, and colors are perfect using the settings in this thread.
However, I've noticed that the black levels are sporadic depending on the source, something I've never noticed with my 42" Samsung plasma. On this TV, one HD show, blacks are perfect. On the next, blacks are horrible. Blacks on Master and Commander are barely decent but not spectacular, but in Max Payne they were fabulous,. Switch to an HD TV show and my eyes hurt the shadows and artifacting are so bad (specifically in the corners), but switch to another HD TV show are they are manageable. Basketball in HD looks crisp with no blur. Does anybody else run into these multiple quality issues depending on what is being watched? I don't want to be adjusting the picture every time I'm watching a show.
I think I'm going to take this TV back and start the search for another one that's not a smart TV, and just run any smart content through my DVD player. If it bugs me now, it will only get worse, right? This is my first LED...are all LED's like this?
post #664 of 698
Sporatic black level could be source related. Make sure that you have the adaptive luma, backlight control and ambient light sensor turned off.
I personally doubt it is the TV. Now if it changes black level on a static image or same sequence of moving clip then you might actually have an issue with the set.
My set black level is ctually better than my Panasonic plasma. No issues there.
post #665 of 698
I think Datagg actually has the M3D651SV model which doesn't have the "backlight control" setting. Instead it has a "Smart Dimming" setting. This is the Vizio local dimming feature and I have found it works well when set to ON for my 651, though I've bounced back and forth a few times. I agree with the other two setting recommendations.
rick
post #666 of 698
rick
Understand. I thought I replied to Thumpin.
post #667 of 698
rick
Hi Rick, it has both.. Back light slider is under picture options... If that is what your referring to. Dim stuff in advanced.
CaspianM may be right and the source (Yamaha is kinda funky) sending signal to the tv. I hope its not that though as that unit cost me a pretty dime. Gonna try DTV to tv, then optical to Yamaha and see if that helps. I did make sure Yamahas encoding is off so signal is not being altered... I wonder if i turned it on it would send source out better. The HR34 never had a a odd signal before, but then again the last tv didn't show detail as good either so may not have noticed. Perhaps hdmi cable not as good either.... I dunno.... All my units, 360, ps3, br player all go through the Yamaha also without issues as far as the signal to the tv being solid...
Edited by Datagg - 3/9/13 at 3:12pm
post #668 of 698
and you did, my bad - sorry a case of bad reading on my part.
Rick
post #669 of 698
Thanks for responding...sorry I was away from my computer for a few days. I've turned off all the settings you have mentioned above, and "tuned" the TV to the specs listed in this thread. I brought in my 42" Samsung plasma (which is really nothing top of the line...just your normal middle of the road 3 year old Samsung plasma) and hooked it up with the same input and the blacks were solid, no artifacting, no static in the dark colors, and the overall picture quality put this Vizio to shame. Even with the DirecTV menu guide the difference is noticeable the the blue to black shading. The plasma looks like the blue is sprayed on gradually, while with the Vizio it looks like it's applied with chunky spray paint.
It looks great with sports and animation, but when it comes to other HD programming through my provider, it looks pretty bad (watched "The Following" and at some parts, it was downright disgusting). I think I'm going to return it and go with the Samsung PN64FS5300 unless I can find some vast improvement in the next day or two- I can run any smart content through my BluRay and xBox.
post #670 of 698
I took my vizio back and got the Panasonic tc60pu54 and its amazing the picture quality, if you don't care about 3d or smart tv it truly is the best plus after its broke in you can do a full calibration through the service menu, hope this helps.
post #671 of 698
There are so much unit to unit variations. I also have a three year old panny which has similar black. But vizio kills it in detail and brightness and overall natural look and higher contrast.
Perhaps it is your calibration ..I don't know or just a so so sample. If you don't care to try another one going to plasma seems a good alternative. You might be happier.
Before returning the set display a 20ire or a solid black pattern on and go the color temp page and play with blue bias/offset reducing it one step at a time unit looks good. You might have elevetaed blue.
Those settings posted here are not really for every set.
Edited by CaspianM - 3/15/13 at 9:24pm
post #672 of 698
I will try that out. I took the liberty of a few screen shots of my problem with the set (obviously they are tuned differently...the plasma is mostly for bedroom nighttime watching so a bit dimmer but I think I shall retune it now after looking at the screenshots). The artifacting in the black is noticeable from a distance on the Vizio, and I didn't even take a pic of where it makes the picture almost look cartoonish (just providing links after the first so as not to blow up the thread). The first example is from the guide screen of the DTV, and you can see the difference in the color transition on a static picture, and it really shows when watching a standard HD movie. The color shots are nearly perfect on the Vizio (second link) and IMO better than my cheapo Samsung plasma. The third shot I zoomed in to show how the blacks are presented on the Vizio - I know up close it's very obvious, but to me it's also this obvious from 12 feet away. Any ideas on why it's so bad, or is this common? Same inputs, same HD channel (which is probably 90% of our type of viewing)
The plasma is on the left, the Vizio on the right (same source, used my DVR). I was hoping that a tuned new LED could achieve somewhat close to the quality of a 3 year old untuned plasma, but I'm woefully disappointed at this point in time. The squares that show up in the blacks and transition blacks is not something I expected. Would this be common if I went with the Sharp Aquos C8470 or should I just hit up the Samsung PN64F5300? I am just looking for a decent quality monitor with no features (I have sound and smartTV covered quite well, and don't need 3D) that doesn't break the bank (<$1600)
(note you can click the pictures themselves in the links below to enlarge them)
http://i47.tinypic.com/1pjn2b.jpg
http://i49.tinypic.com/2m28fbk.jpg
Edited by Thumpin - 3/16/13 at 9:22am
post #673 of 698
I believe those blocks are mpeg artifacts a source related and you'll get them with all TV's. And as why Plasma looks better is a matter of different technology. Plasmas hide lots of imperfections but not LED.
Led is more revealing, sharper and harsher a bit. Also size of the TV is another factor. Make sure your color level is not set too high. If you look close micro blocks are there in plasma too but smeared.
On your plasma sharpness is way high resulting different artefacts such as jaggedy edges. See the numbers alonge the edges. Look bad.
Edited by CaspianM - 3/16/13 at 11:33am
post #674 of 698
Thanks...I'll go through and tune my bedroom plasma - I don't think I ever bothered since the wife mainly uses it to watch Housewives of (Fill in the blank) and HGTV. If these blocks are source related (and they are an issue for me), do you think I will find the Samsung plasma PN64F5300 a much better set given I don't need sound, 3D, or smart features? I don't ever recall seeing them with my DLP that this set replaced. I will check the color level and see if that improves anything...the latest Walking Dead came out today and that show really shows off the quality issues I'm having. Oddly enough, I popped in a normal DVD for my girls of Monster High (a cartoon) and there were absolutely zero issues with the picture. Definitely frustrating. I really appreciate you taking the time to respond to me here over the last week and change.
post #675 of 698
Your set is showing all there is to the signal is getting faithfully. Look into changing your provider. Decompresion artifacts are bad.
I wouldn't change set to band aid the issue. But you really cannot change provider try a plasma and see.
Also experiment with mpeg NR and smooth motion in the menu.
Edited by CaspianM - 3/18/13 at 4:54am
post #676 of 698
Locked into Direct for another year so can't do that....not that Surewest would be much better smile.gif I ended up just taking it back an hour ago after trying everything you suggested with no viable difference in what I was looking for. I think I will be heading back to plasma...looking at the PN64F5300 or the PN64E533. Seems another person had both side by side and there was a huge notable difference in the blacks...enough to make a starry night blurry on the Vizio and perfect on the Samsung after tuning. I'll give one of them a whirl and see what happens! Thanks again for all your help....much appreciated.
post #677 of 698
Get this for the same price Panasonic TC-P65S60
post #678 of 698
Oh nice... a Panny - I wasn't even aware of that one (but aware Panny's are the top of the selection). Thanks for the heads up...I will go take an immediate look! smile.gif
Virtual beer for you!
post #679 of 698
Beer looks good. Have fun
post #680 of 698
final update. i decide to return the TV - gotta love Costco - between the blooming and the ridiculous delays it was starting to piss me off
I ended up replacing with a Sharp Aquos 70" LC-70C6500U - definitely worth the additional $300 outlay
startup time is under 3 secs and i still get all the 'smart' apps.
post #681 of 698
What TV did you return. i have a M3D651SV and dont have any of those issues. We love the set, 3D rocks, apps work good yet not top notch in the GUI layout, yet work great... No issues thus far, Knock on wood....
Congrats on the sharp..Was looking at that one also, yet wanted 3D and they only have the active units not passive... Passive is so much better than active IMO as i owned a 73 mits with it....
post #682 of 698
don't have or want 3D - gives me headaches in the movies - can only imagine how bad TV would be....
post #683 of 698
Thanks for the clarification..... I got headaches from active so I get that... passive though, not at all.... the people that watch 3D here at my house are amazed.... great tv.
post #684 of 698
I got my TV in January and still have firmware 2.31.447. I have been trying to use the Amazon app and most times it hangs after trying to watch a movie and locks up the TV where I have to unplug it. I have a solid 10/mbs download speed and hard wire to my asus rt-n66u. I was hoping for months now I would get the updated firmware so at least I could determine if that was the cause. I can use the xbox360 with amazon and that has no problems.
post #685 of 698
Hey everyone I am new to the fourm and I have been having trouble since day 1 with my 65 inch TV I got from Sam's. I love my TV and wouldn't want to trade it for the world. But the trouble I am having is with my dlna aka my media center. Now im able to watch movies through it which isn't the problem. There are certain movies that will work and certain movies that when I click on them my TV screen goes black and my Vizio symbol gets really bright. So my question to you all is why is my TV shutting down?
post #686 of 698
I purchased M650VSE a week ago from Costco but am not satisfied with viewing angle. I often sit 45 degrees from center but colors wash out quite a bit. In fact, colors start washing out event if I move from center slightly (a couple of feet). My viewing distance is 10 feet. I went back to Costco to see how Sharp and Samsung do but could not tell due to the content Costco running. I also saw new E650iA2 but again it’s hard to tell whether it has better viewing angle.
Is Sharp or Samsung better as far as viewing angle goes? Or is E650iA2 better since it’s direct LED? I don’t want to bring a bunch of TVs home and return them even if Costco has very generous return policy. Well…if I can avoid returning them.
My budget is under $1500. So if I decide on Sharp or Samsung, it’ll be 60”. Or I can try new Panny 65” plasma but that will be my last pick.
Any help or advice would be appreciated.
post #687 of 698
The only alternative is to go plasma. I have a smasung ES series and it is the pretty much the same as my VSE. Don't waste your time exchanging it with another led if that is your problem.
Another solution is do not sit 45 degree off axis.
post #688 of 698
Can someone please answer my question about my TV shutting down???
post #689 of 698
Thank you. CaspianM.
I'm going to bring the Panny plasma and try it today.
By the way, M650VSE is pretty good if you watch if from the dead center. Use the picture setting in this thread. It's hard to beat for the price, I think.
post #690 of 698
Bah Im going crazy. can someone please help me??
