AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Is Dynamic Mounting still the only option for mounting over the fireplace+dropping it down?
post #1 of 3
If you recall (and you won't lol), I got a 65st30 around May last year and was interested in mounting over my high fireplace. It was kind of a bummer that the only option at the time (without paying more than the TV cost) was the Dynamic Mounting style mount. It was like 400 bucks, which was way too steep.
And I was wondering, is Dynamic Mounting the only option out there under $500? I might have to bite the bullet...
Thank you!
post #2 of 3
I guess so? lol...
post #3 of 3
Ok, well I decided to bite the bullet and went for it. Never saw a review for http://www.DynamicMounting.com and the 65ST30 or any of the 65" heavy plasmas.
But the tv is just shy of 100 pounds and it works great with my high mantle. I'm really impressed by the craftsmanship - seems solid. If it was cheaper that would be ideal, but if you're in a situation like I was then it was basically mount it up there or find some odd place to put it... I'm just glad it's off the coffee table lol!
Also, the install went fine with 2 people which was nice.
