AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung PS64E550 WIFI issue. Please help
post #1 of 3
Hi guys,
First of all I can't seem to find anything on the following issue.
This arvo I went to check for a firmware update, I turned on the Internet hot spot and tried to connect. I didn't find any of the two wireless routers. I gave it a cold boot and after that it started to freeze when it came to network settings. So I turned it off and on then more of the same.
I upgraded the firmware, no help. Called Samsung before that but not much help. I'll try them tomorrow again.
I found out how to access the service menu, and it says wireless status: MAC Fail.
And now I'm stuck. Tried a factory reset from the service menu and that didn't help.
Hope someone can help.
Ritzo90
Sent from my HTC Desire using Tapatalk 2
post #2 of 3
Fyi just call samsung, the wifi catd is ****ed
post #3 of 3
I had the same problem ... when I first turned it on - it found the home network ... then never again ... (tried countless times over the next 2 months). Contacted Samsung (who were great in their follow up) - they even sent me a firmware update on USB - tried the same as you - firmware update; hacked the BIOS (there are sooo many settings to play with) and reset the TV - the BIOS reported that the WiFi module had failed.
Got in touch with Samsung who answered the phone without delay (an absolute first!!!) who then liaised with a service repair place. Unfortunately the TV was on a bracket on the the wall - repair people would not take it off the wall ... on its return they would only return the TV to just inside the front door which meant I had to get it upstairs and back onto the wall ... no mean feat !! Turned out it was a faulty WiFi module ... which was replaced as well as the main PCB board ...
