AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Too weak 3d signal epson tw9000 or 5010
post #1 of 2
Yo, sending the 3d signal thru a hushbox. The 3d signal seems extremely weak. I've managed to get 3d a few times through the box glass window but mostly it doesn't react.
I'm thinking about this one http://www.amazon.com/Epson-V12H484001-External-3D-Emitter/dp/B005ZSD95K
external 3d emitter
Will it do the trick? Where should I put it and so on. I am really clueless how this works.
/maxxy
post #2 of 2
Had a lot of trouble finding the answer for this. You can simply buy an external 3d emitter connected with a single network cable to projector and thus have it outside the hushbox. It works nicely.
