i do not have a sub, here is my setup.
about a 15x20' living room
my system will be more used for video games and blu ray, not much music
Fronts, two of them:
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290204
center:
http://www.amazon.com/gp/product/B002778F88/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B002778FAQ&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0TPFYWY1BRHNAA0R1QH4
receiver
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117409&Tpk=pioneer%20vsx-822
sourounds: two them
http://www.amazon.com/Boston-Acoustics-SOUNDWAREB-Soundware-Black/dp/B000UTNQWA/ref=sr_1_13?s=electronics&ie=UTF8&qid=1352311956&sr=1-13&keywords=boston+acoustics
still need sub
Which sub should i shoot for?
i do'nt want to spend over 200, really d'ont want to spend 200
need to have it auto turn on when i turn the receiver on
couple choices i have found
http://www.amazon.com/Surround-Theater-Powered-Active-Subwoofer/dp/B0052OGTBS/ref=sr_1_5?ie=UTF8&qid=1352313556&sr=8-5&keywords=subwoofer+12+surround+sound
http://www.amazon.com/Polk-Audio-12-Inch-Powered-Subwoofer/dp/B000092TT0
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M
please help me choosE!!
thank you so much
Edited by ryanderenzy - 11/7/12 at 12:50pm
center:
receiver
sourounds: two them
still need sub
thank you so much
