AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Nintendo › Wii U sensor bar behind acoustically transparent screen
post #1 of 4
Can a sensor bar be mounted behind the screen and still have the system pick it up. I am running a PAE 7000 with a 110" screen. I dont want it located at the bottom or top but "behind" the screen.
Regards
post #2 of 4
The bar is actually an IR light source. So imagine shining a weak LED flashlight through the screen which will probably block it entirely. IR follows the same rules a visible light except we can't see it with the naked eye. Any opaque material will block it.
post #3 of 4
Thanks. Guess that is the challange with a sensor bar and a large screen.
post #4 of 4
I mounted my sensor bar below the screen. No issues.
  Back to Forum: Nintendo
