OK,
So I am dead in the middle of a complete server overhaul. My Current server is running WHS2011/FlexRAID with an H61 Asrock Motheroard, 8GB 1600mhz Gskill DDR3 and a G630 CPU. (I bought the ram thinking I would upgrade the board)
I have purchased a new Asrock Z77 Extreme4 motherboard, a supermicro x8 Sata card and 4 more 3TB HDD's. BUT I NEED A CPU !!!!
Normally it would be easy to pick- But my HTPC is currently running a 3570k I picked up at Microcenter for $120(motherboard combo w/ Asrock Z77 PRO3) I feel it's possibly over kill since I only use my HTPC to play mediabrowser/XBMC or manually play a movie off my server. That's basically it.
I have have a full time i7 Desktop I use to rip, encode, manage and do almost all my PC related tasks. I add content to the server via the desktop and the HTPC simply plays it back on the TV in a convenient viewing location.
I wanted a 3570k in my server since it transcodes on the fly PLEX; I'm considering using the HTPC CPU for the server and replacing that with something cheaper. So that complicated options.
The reason I am in a rush is Cyber Monday deals. I need to buy today.
Here's what I am seeing:
$79 i3 2105 CPU for $79 (Might make a nice HTPC CPU. Only $80 and the 3570K gets transplanted to my server)
http://www.neweggbusiness.com/Product/Product.aspx?Item=N82E16819115090
Vs.
Intel Core i5-2310 @$159
http://www.neweggbusiness.com/Product/Product.aspx?Item=N82E16819115089
Vs.
Crazy Idea- Use my Desktop 2600K CPU and get the Intel Core i7-3770K for that. Temped but not needed @$249
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2372989&SRCCODE=LINKSHARE&cm_mmc_o=-ddCjC1bELltzywCjC-d2CjCdwwp&AffiliateID=lw9MynSeamY-RT0YOjzlWYYvxKJtgCya.A
Vs.
G860 (Almost an i3 right ???) for only $57
https://www.superbiiz.com/desc.php?name=G860BOX
Vs--- ANY BETTER IDEAS???
NOTE: I am planning on building my bother a HTPC for Xmas with the current H61 and G630 from my server and is only reason I am not just using the G630 CPU in my own HTPC.
I am looking for most bang for my buck.
Thoughts?
Advice?
Vs.
Vs.
Vs.
Thoughts?
Advice?
