AVS › AVS Forum › Video Components › Home Theater Computers › Planning to rebuild my 20TB WHS Flexraid server: Information requested.
Planning to rebuild my 20TB WHS Flexraid server: Information requested. - Page 18
post #511 of 916
Originally Posted by Mfusick View Post
Oh.. that is not the backplate. that is the internal fan plate. But yes... that looks perfect.
Yea that's what I meant.
I still need figure out the back ones though.. they are the loudest.
Perhaps just replace with quieter model and slow them down ???
Anyone have advice on that? Use fan controller ? Or 7v trick ?
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=-1&isNodeId=1&Description=noctua+80mm&x=0&y=0
post #512 of 916
post #513 of 916
post #514 of 916
$20 a fan just somehow hits me wrong. I might buy the plate today... and use a few of the crystal clear Rosewill fans I have that are 120mm and I paid $2.99 for in a 5 pack.
They are going to be much quieter than the Norco Jet engines.
I will probably use the Y splitter and run them off the motherboard fan headers- and enable fan speed control and this should allow them to slow down when the machine it not running hard.
post #515 of 916
I posted this in another thread.. but perhaps should have put it here. I messed around in my flexraid and dropped out a hitachi 2TB and a couple 2TB greens that had errors.
My drives are full and I am looking to start up flexraid again with new config. I am trying to figure out how long this will take.
So I dropped out three drives (GREEN DRIVES) and I want to initialize my server with my Seagate 3TB and 1 Green WD 2TB. My Green 3TB WD is my Parity drive but this is temp.
So I basically have:
Seagate 3TB#1
Seagate 3TB#2
Seagate 3TB#3
Seagate 3TB#4
Seagate 3TB#5
Seagate 3TB#6
WD 2TB
WD 3TB PRU
Total is 20,000 GB right ?? (20TB) 3000+3000+3000+3000+3000+3000+2000 ( give or take for 1024 thing)
So I am watching it tick by and the lowest I see the Parity Computation process speed reach is about 85MB/s
So that means it's processing data at 85MB per second right ?
So then.. could I divide 20,000 GB by 85MB per second = 235. Does that mean it would take 235 seconds ? That makes no sense to me. Obviously I am an idiot right ?
So then I thought
85MB second = 85x60seconds= 5100MB per minute. That's 5GB right ? So it's doing about 5GB per minute? (Still seems fast right ???)
So that means 20,000 GB divided by 5GB per minute = 4000 minutes. That seems about right ???
so 4000 minutes divided by 60 = 66.6 hours.
That means it's gonna take this pig 66 hours to finish ????
Seriously ????
I mean I have some spare space (at least 200GB per HDD) and the proccess is sometimes faster but with the green drive as parity I think it's limited to a combo of how fast CPU can process parity and how fast the slow green drive can record it.
so I guess 50 hours would be a reasonable expectation ???
holy smokes !!!
Am I even close ??? Or does my math and brain just suck ????
post #516 of 916
It's the price you pay for RAID greed.
post #517 of 916
Dividing 20k GB with 85 "MB" is wrong since the units are different. For simplicity, let's say there are 1000GB in a TB. That would mean 85MB is 0.085GB. Now dividing 20kGB by .085GB gives you roughly 235294 seconds which is roughly 66 hours. So yes, it would take 66 hours to compute parity for 20TB. That seems about right. I get 85MB/s parity calculation speed too with my WD Green drives. It took me about 11 hours to compute parity for about 3TB worth of data. And you have roughly 6 times more data than me. So yea, everything is going normally.
post #518 of 916
My ZFS rig would resilver that 20GB in 10 hours. (Sorry, I don't mean to be an a-hole, I just love the performance I get out of my ZFS rig and can't help but brag about it.) biggrin.gif
60+ hours is a long time.
post #519 of 916
Both FlexRAID and ZFS has their advantages and disadvantages. I wouldn't particularly call one better than the other.
post #520 of 916
"Performance" when building a software RAID array/parity.
That's a new one on me.
Carry on...
post #521 of 916
FlexRAID is still probably the "fastest" software RAID solution out there. Because it doesn't strip the data amongst drives, accessing files from different drives at the same time would give much faster read speeds overall. Not sure if I worded that properly, but I hope you all can understand what I mean frown.gif
post #522 of 916
Right,
Hardware RAID is faster but software raid is more flexible.
post #523 of 916
I'm jelly.
But honestly...
I did 20TB and it was done when I woke up this morning.
It did not take as long as I thought.
post #524 of 916
I'm jelly.
But honestly...
I used 4TB parity with a 105 MB/s parity rate but it only took 11 hours total for my array, which is six drives (20TB)
post #525 of 916
ZFS is software RAID... but add more vdevs, and you get more performance. It's almost linear, two vdevs... double the performance of one. Three vdevs... triple the performance of one. ZFS was built in mind for commodity/consumer level hard drives and HBAs. FlexRAID is limited to the performance of the one hard drive you are reading/writing to. Now, I understand for most media storage, that a single hard drive is pretty capable, some even match gigabit speeds. But as you discover, parity calculations suffer, and you are doing this daily/weekly/monthly. With ZFS it's on the write. And rebuild times suffer with FlexRAID because you are limited to the performance of that one hard drive, usually the slowest of the bunch.
post #526 of 916
It's not astronomical, but pretty good when I still have green drives in the mix.
post #527 of 916
Lol I am sure you meant 20TB and not 20GB. I was making fun your typo wink.gif Unless you really meant 20GB...
Since ZFS strips data, loosing more drives than the # of parity means losing all data. That really scares me frown.gif I know chances of that happening are slim to none, there's still a chance. Plus you will need a separate box for it unless you use bare-metal hypervisors to virtualize all your boxes in one. I have played around with FreeNAS quite a bit. The features it offers for a free product is amazing. ZFS really does intrigue me quite a bit, but integration within Windows was a BIG plus for me when it comes to FlexRAID.
post #528 of 916
Advantage of Flexraid is data is still on drives even if machine or controller card die
post #529 of 916
Just one of many advantages.
post #530 of 916
Side question:
What should I set WHS2011 power options to be ?
Should I turn of HDD "NEVER" or should I turn off after say 30 min ????
What is the advantage and disadvantage ?
Would turning them off save $$ on electricity, but just cause them to have to spin up and a small delay when first accessing the server ?
post #531 of 916
Another side question?
How does everyone have network sharing setup?
Flexraid wiki mentions to turn off homegroup since it interferes with builtin storage pool sharing
I keep getting a BSOD with a IRQL_NOT_LESS_OR_EQUAL error when a networked PC tries to access any of the flexraid shares
File/printer sharing is on for both
Password protected sharing is off
Homegroup is not created
post #532 of 916
And you created the shares in Windows first, then copied the settings in FlexRAID right?
post #533 of 916
Any shares I create outside the flexraid pool work just fine. I can choose them either through the "Map Network Drive" dialog window or clicking through the Network -> Computer Name -> Share Name
Either way works outside the pool, but as soon as I choose one of the Flexraid shares the server (windows 8) has a BSOD with the IRQL_NOT_LESS_OR_EQUAL error
post #534 of 916
Followed this guide, but W8 instead of WHS http://wiki.flexraid.com/2011/12/03/accessing-your-storage-pool-over-a-network/
post #535 of 916
The Flexraid drive has the shared drive icon (like the image, but it's not a DVD drive smile.gif )
The "Share With" context menu option in the subsequent folders allow me to select "Advanced Options"
The resulting dialog window has a checked box next to "Share this folder"
post #536 of 916
Try changing it to a non-removable and NTFS drive
post #537 of 916
I don't set up any shares.
I just set sharing on the V drive ( Flexraid) to full permissions. This in WHS.
Then in Flexraid I do same. I share the freakin' drive.
I don't set up individual folders to share or not.
I want it all shared. I share the root drive.
Everything it contains is then shared.
Folders are complicated and odd stuff happens.
post #538 of 916
Deleted all share configurations and shared root Flexraid drive instead (I'd read somewhere not to do this)
Still get the same error
I think this might be a W8 driver issue
http://forum.flexraid.com/index.php/topic,1579.0.html
post #539 of 916
Already using these settings
post #540 of 916
Why would you not want to share the whole drive?
That's what I do. That is what I want. I don't want to share individual folders. That is a mess.
