Originally Posted by Andy_Steb
Starting to wonder how you got it to flash in the first place. A lot of consumer boards have problems with option roms, they just don't leave enough room for them.
With the option rom disabled you would think it would boot up.
The card is a 8x pcie but will run at 4x. Try a different slot.
If all else fails, send it to me and I will reflash it for you without the rom.
Thank you for the offer. I dont have any other mobo s right now. Will probably have access to one in a month or so. Will try then i guess. The mobo is a nforce 680 sli. So it is rated to run at 8x/8x. No onboard graphics. So I have to run one pci-e with my gpu. Even then it must run both at 8x i think. Ill try in some other mobo and then decide. Thank you for the help guys.
