Originally Posted by
Mfusick
Anyone know a good slimline Bluray reader for a Norco bay ?
Skip the optical drive in the Norco, unless you rip directly on the server. Less heat, less cost, one more Sata available to you through eSata...
I have a Norco 4020 and the only time I needed optical was when I installed the OS, from an external DVD player. I rip from a client machine.
One more thought : if you don't have an external DVD player handy, nothing prevents you from using a full size DVD player on an "open case" server while you install the base OS, then close the cover...
