I have a pair of JL12W1 subwoofers that have been laying around. Had them in a car audio application for several years but thought it would be neat to give them new life in my HT.
I already have two powered subs from DefTech in a set of bi polar towers. I think I have positioned them to the best of my ability but still think the bass response could be more uniform and deeper. Reading around it is suggested that multiple subs can yield smoother response overall. Room is 40' x 17.5' by 9'. Kinda large.
Meeting the WAF, I have an area with maximum external dimension of 50cm x 60cm x 89cm towards the rear of the room. This includes about 5cm room around the enclosure for RCA cables on the side(s) that back up to the walls.
The subs are 8 ohm each and will be wired in parallel so I want to keep them in the same box and plan to power them by a BASH 300W RMS plate amp. Technically more power then the subs can handle but.....
So I dreamed up the transmission line type enclosure seen in this post. Thinking about isobaric configuration so that the cross sectional area of the TL can be reasonable and allow me to get close to the 1/4 wave length that is desired.
Note that in the cross section picture, the lower woofer would be open to the room on two sides.
Plan on using 3/4" MDF and making a nice winter project out of it. I have two spreadsheets from websites dedicated to TL Speakers to aid in my line calculations. But nothing yet that I think could simulate the response. I will be measuring the Thiele Small parameters of these subs one weekend when I get some quality time in the lab.
All the boxes I have made in the past were sealed for vehicles. So this will be more of a challenge.
Edited by Gaugster - 11/11/12 at 6:41am
I can hear air leaks but one side isn't sealed
