The bleeding edge art of overclocking an HDTV to 120Hz...
True 120Hz from PC to TV:
Make Your HDTV Accept Real 120Hz Refresh Rate
In the last few years, HDTV's have gained more internal electronics circuitry to do 120Hz. Internal 120Hz processing. Frame-sequential 3D at 120Hz (60/60 per eye). New HDMI 1.3a with enough bandwidth to pass 120Hz at 1080p if tasked to do so (unofficially). Finally, the whole chain finally made it possible to do TRUE NATIVE 120Hz on several televisions, from a computer, at least unofficially. In addition, some computer users overclock their computer monitors to a higher refresh rate than reported by EDID (e.g. Catleap 2B, or the QNIX Q2710 Evolution 2, or the X270OC). Dozens of success reports are coming in!
Also, improve your successes by:
-- Using a high quality HDMI cable (3D / 4K compatible) even if the HDTV has only HDMI 1.3 ports
-- Try all ports on TV
-- Try all ports on computer
-- Do not use any adaptors (Do not use DVI-D to HDMI adaptor)
-- Bypass your receiver if it's an older one (Not all receivers can pass 120Hz HDMI)
-- If you fail, there's always 720p@120Hz which is much easier.
No fake frames. No interpolation tricks. No Motionflow voodoo. True 120Hz!.
Try this with your existing HDTV. Post your success reports here.
Edited by Mark Rejhon - 6/15/13 at 8:49pm
Successful: Vizio e3d420vx
Resolution: 1920×1080 at 120 Hz
Source: http://120hz.net/showthread.php?852-Managed-to-force-120Hz-on-a-Vizio-e3d420vx
(Third-Hand Report) Success: Panasonic VT50 plasma
Caveat: More heat output
Source: http://www.avsforum.com/t/1438092/list-of-hdtvs-with-120hz-native-refresh-ability-forcing-1080p-120hz-via-dvi-or-hdmi-from-computer#post_22576928
Confirmed: Seiki 4K HDTV
The brand new SEIKI 50″ HDTV with 4K resolution supports 1080p @ 120Hz natively (Multitool confirmed).
Originally Posted by deadman5k
Successful: Vizio M420SL not a 3d TV
Using a Asus 3D tv driver I was able to force a 120hz output with windows 7 and my Vizio M420SL system info screen displays 120hz vertical frequency as well as my Catalyst control center. This TV is not a 3D but does have a native LCD refresh rate of 120hz.
Thank you blurbusters for your very helpful information. It took all day to find the right question to ask the great google search engine but when I finally asked “force 120hz pc” I found this page and now I am in 120hz, 42 inch, goodness. Next trick is getting passive 3d working. Thanks again.
Originally Posted by sadbuttrue
Successful: Panasonic 50ST30 plasma
Resolution: 1280×720 @ 120hz.
Source: HardForum post (by sadbuttrue)
The OSD reports 60hz and 3D mode detected. Colours are slightly different but there is no 3D being applied. I have verified that it does show 120 unique frames. So, when you try outputting 120hz to your TV don’t assume the OSD is giving an accurate report. It may say 60hz yet actually be showing 120hz.
Originally Posted by maarten12100
Successful: Skyworth 39E780U UHD tv (china market model)
Resolution: 1080p @ 140Hz without frame skipping
Source: Overclock.net review by maarten12100
The overclock results:
UHD 3840×2160 was 30Hz max now 38Hz (up to 40Hz by reducing the extra pixels/blanking in the stream but with minor artifacting)
QFHD 2560×1440 was not there now 82Hz
HD 1920×1080 was 60Hz max now 140Hz (I checked with RRMT Refresh Rate Multi Tool and it actually did it without dropping)
QHD 1280×720 was 60Hz max now 254Hz (checked again with RRMT but it was too fast for my eyes then I took pictures and video)
(NOTE: Cost only $600 in China! Not available outside of China yet at this time.)
HDTV Overclocking Instructions: Get 120Hz from a PC to a televisionOriginally Posted by bobbitybob
Successful:
- Sony KDL-50R550A 50″
- Sony KDL-60R550A 60″
- Sony KDL-70R550A 70″
Resolution: 1080p @ 120Hz
Source: AVSFORUM post by bobbitybob
“720p@120hz confirmed working. Kinda funny, before on 1080 I didn't notice a difference figuring I'm just getting too old for this stuff, having never used a 120hz monitor before, but I knew instantly with the real 120hz that it's working. What a huge difference in smoothness and reduction in blur. Just nuts. Tested with RRM (Refresh Rate Multitool) as well to verify.”
(NOTE: 720p was good; 1080p was frameskipping, but may be DVI adaptor (limitation). Best to test using direct HDMI-to-HDMI connection from PC-to-TV.)
Successful:
