Well fisrt of all, hello everybody i'm kinda new here. Well getting into my question, i have a doubt about a purchase i'm going to make right now. I'm thinking of buying this Home Theater In A Box from Yamaha, the yamaha YHT-397. I read that this is a very good entry HT and it does have very good reviews from customers even better from a Onkyo.
But that doesn't guarantee me to make me buy it right away. I kept reading plenty of specs around the web and some forums, and i read something that kinda disturb me a little. The Yamaha YHT-397 it suppose to output a 100 w RMS signal per channel, in a total of 600 w RMS, now from some review sites (plenty like cnet,etc) states that the front, surround and center speakers are a 30 watt output signal: http://reviews.cnet.com/home-theater-systems/yamaha-yht-397/4507-6740_7-35409754.html ---- It says right there on speaker system. Now if someone can tell me if this is true or it is just like a minimum output signal and it is truly a 100 w RMS output, very appreciated if someone answer me these. Im looking forward to buy it perhaps tomorrow and i need to know if i will get my 600 w RMS total output. I'm sort of a newbie on this type of things.
Thx for your time and answer
. Another quick question , and sorry for being ignorance, when you say 30 w been nominal power and 100 w been the maximum, that means when you are reaching some volume levels the power of the speakers is dynamic? it means can get up to 100 w, or go down to the 30 w level or it is constant?. Thx for your answer otto
). That's a very important stuff also, you said something about the room size and makes me think about it.
