Hypothetical Question: I was planning on running a whole home amp to multiple zones in my home, with the caveat that in specific zones I would place powered subwoofers with speaker level inputs. I would wire them in parallel with that zones speakers as the input the the sub amplifier is high impedance such that it would not significantly affect the load presented to the whole home amplifier. In my haste, I assumed the volume of the said subwoofer would also scale with the position of the volume knob in that zone. However, I think that operation may depend on how the volume control actually works. Does it simily add incremental amounts of impedence into the line to attenuate the current through the speakers? Or is there a transformer game being played here? If is simply adds impedence that will do nothing for controlling the volume of the subwoofer as the voltage present at the subwoofer high level will not change. If the voltage is controlled by a transformer then by placing the subwoofer high level inputs downstream from the volume control, I imagine it would work as intended. Can someone help in my dilema?
Theeld
Theeld
