what I tried to do is streaming big mkv file to ps3 which connected to home theater.
1. had ps3 media server installed. ps3 found my PC
2. Got a big mkv file, over 9GB single. converted to mpeg2 with mkv2vob successfully.
3. ps3 found the file, BUT can't play it.
Question
1. Does ps3 only recognize the file less than 4 G? if yes, that could be the problem.
2. Does mkv2vob convert the file and automatically split them to chapters which can be played like real blu-ray disc?
3. if question is no, then what is the solution?
4. do we have to convert mkv to something ps3 can read? or is there program we can install in ps3 and make it play mkv directly?
thanks a lot.
Question
thanks a lot.
