Adding an iScan Duo to my home theater and I'm debating the best way to do the hook-up. I tried inserting the Duo after my AVR and then passing it through the Darblet then to my projector but had a lot of lip sync that I could not adjust either way to get it to look right. The only other way to hook this up would be to run all my inputs into the Duo and send the HDMI signal to the AVR for audio processing then out to the Darblet on to the projector. This seemed to work better for the lip-sync.
Just wanted to get some feedback from Duo or Mini users as to how you are using these processors with your other components. I would eliminate the Duo altogether but I am using it for CMS with my projector. Suggestions please....
