AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Integra DTR 40.2 Powers up no sound
post #1 of 17
This happened for the first time last night. Sarted system with the My TV button on remote. Cable box powered up, Receiver powered up tv started but no sound. Looked at all devices and found zone 2 led on. I don't know if this is usually on but nothing is connected to zone 2. I turned zone 2 off from the front panel and restarted the same as before, still no sound. I switch over to the tuner which is internal to the reciever but still no sound. Volume level responds to remote or front panel. Got out the manual and checked using the trouble shooting guide, sleep timer(off) and several other setting that I cant remeber now but still nothing. Cable box is connected with HDMI to receiver, TV is connected to reciever with HDMI, Blu ray is connected with HDMI. Tv picture was on. Switched over to Bu ray and tried a dvd but same thing, no sound. The manual described a reset pocedure with the remote. I did that then restarted and the system did start. I also noticed a familiar click right before the sound starts which may be a relay latchig to power up the internal amp. (receiver is the amp no external amplifier). Then I had sound. I thought all was okay. This morning my wife turned the system on again pressing my tv on the remote and the same thing happened as last night. Picture is on reciever display on, dislay shows volume level and sound mode (all chanel stereo) but no sound. I shut every thing down with the all off button on the remote then turned each component on one at a time with the remote. this time after the reciever powered up I heard the familiar click and sound came on. I know this is the same machine as an Onkyo model but I am not sure which one. Has anyone experienced somthing like this? Any suggestions? I did read in the manual about a flashing led that indicates an overload but I had no such flashing.
Ckartson
post #2 of 17
I'm having the exact same problem. Last night I had no sound, and then all of the sudden, sound came on... I watched TV and turned everything off when I was done. Tonight I turned the receiver on and again had no sound... I reset the receive like you did to no avail. I'm calling Integra support right now. Let me me know what happens with you.
Jason
post #3 of 17
I have the same problem with a 40.3. If I start the receiver set to ANYTHING HDMI connected, no sound. If I switch to tuner, or net, or anything NOT HDMI connected, shut off the receiver, and then power back up, I have sound. Not the way I want my expensive home theater system to work.
Anyone found an answer to this?
John
post #4 of 17
I took mine in and they sent it off for repair - it's still under warranty. In the mean time, I bought a diff. receiver (Marantz 6007) and will return it... Not overly impressed with the Marantz. Doesn't sound as clear as the Integra.
That being said, since Onkyo makes Integra, and Onkyo's are prone to overheating, I'm guessing that's what happened... but who knows. I may sell the Integra when I get it back and get something else. Might try a Yamaha.
Jason
post #5 of 17
It sounds like you guys are experiencing an HDMI handshake problem. Or a loss of the handshake. It is possible to have just video and no sound if the HDMI handshake isn't completed properly. You may want to try turning on the equipment in a different order manually instead of my a remote using a macro. Sometimes all in one remotes turning everything on at once can lead to HDMI handshake problems. The more expensive remotes can have delays set for different components when things are powered up. This allows the HDMI handshakes to take place in a timed fashion.
post #6 of 17
That's not it - at least in my case.
I've been using this receiver every day for two years with the same equipment and NEVER had this problem. I've already tried the powering off and turning things on in order process already anyway. No matter what I did, there was NO sound. I wasn't even getting sound from the speaker level calibration screen. And, I'm not using expensive remotes... just the normal ones that come with everything. No macros in use here.
Jason
post #7 of 17
I had the same problem happen about 2 weeks ago with my 40.3. All of a sudden no sound on any HDMI input (CD/DVD/Cab/SAT). I get video clear as day, but no audio signal. If I flip through listening modes or turn the receiver off and on, I hear a click at some point and the audio will come on, but it's sometimey. Most of the time it doesn't work. I'm trying to avoid a repair visit, but think I may be at that point.
Did anyone manage to find a solution to this that didn't involve taking it in to the dealer for repair? I'm not pleased that a $1,000 receiver is having these issues and I've had mine a couple of years now I think. I need to check the purchase date, hopefully it's still under warranty.
post #8 of 17
I'm having the same issue with my DTR 40.3 at first it would power up with audio and then after a while the audio would go out even if you were using a non-hdmi source. Now I get no audio at all through any source and when I try to do the Audyssey setup with the microphone I get a wait screen on the receiver that never initiates the test tones. I've tried everything including the master reset, and leaving the receiver unplugged for 24 hours (cause someone said to try that to get it out of circuit protection mode). Gotta say I am extremely disappointed in the quality of this receiver and I won't be making another Onkyo/Integra purchase ever again.
post #9 of 17
My Receiver is having the same issues, only its more than no sound.
I ALSO am not seeing the network or firmware update options light up.
I did the reset (Hold VCR while pressing the off button. "CLEAR" comes up right after).
I did manage to get the Firmware option to light up after I did a few resets. I figured that maybe the firmware was bad so I did an update and it stated that I already had the correct version installed.
So now I am sitting here with a receiver that is just over a year old, with the passthrough on and the audio on mute. I am at least able to send the sound from the cable box through to the TV.
I am at a loss right now. Maybe I should have not chosen an integrated receiver? I did worry about having that many bells and whistles in one box.
Now I am wondering what the next receiver should be after I get this one fixed and ebay'd....
Good times... I do not have the time in my life to be dealing with crap like this. This is the tiny little detail that I am sure the folks at customer service will glance over while they listen to my problem.
So if someone wanted to up the game and spend $2k on a receiver setup - should I go with another all in one (Integrated) or go to components (Preamp + Amp)?
post #10 of 17
LOL. What a waste of money.
post #11 of 17
100% seperates. Might try the Emotiva UMC-200 and the XPA combo.
post #12 of 17
Hey guys
So, I am no expert but I have tried this solution and it works. For those with the HDMI handshake issue where you can see video but get no audio and every now and then when you leave it on for a while sounds comes on. Well it simply means your HDMI board needs to be reflowed. A simple test can be done by opening the unit, using a hair dryer, heat up the board for about 2 minutes and surprise your sounds will start working.
If sounds plays, remove the board and get someone to reflow the chips for you. Google for DYI.
Hope this helps. Hit LIKE if it worked for you or if you found it useful.
Cheers
post #13 of 17
I am having the identical issue. I had intermittent loss of network connectivity (noticed instantly as I use IP control), did a firmware update when I got it to finally connect again and now I have no network connectivity and no audio on any HDMI sources... Just awesome. I had it in once under warranty already to fix a network connectivity issue.
post #14 of 17
I spoke with the store owner that sold me my Integra DTR 40.2.   He indicated that it is likely the digital processing board that takes digital audio and converts it to analog.  It is a $300 repair out of warranty which is difficult to swallow given that you can buy the DTR 40.2 for that amount on Ebay.
post #15 of 17
Fantastic. Mine just started doing this this morning as well. Last night, worked just fine. This morning, (and now night as well), no audio when I turn it on.
post #16 of 17
Exactly the same problem I'm having with my Integra 50.1 . Really annoying after spending so much money on it. Bought through an installer who is no longer in business so not sure who to take it to in Sydney to get repaired? Certainly a HDMI handshake issue it sounds like. No audio on any devices cd DVD TV vinyl. Interestingly the zone 2 for outside speakers works just not the internal speakers?
Where to get repaired is my main question it's 1 yr out of warranty.
post #17 of 17
I am having the same issue on my 40.2. Background: Our blue-ray player was hung up and just spinning so my wife was going to unplug it and reset the player. She know what cord it was so she just pushed the the on/off switch on our monster surge protector. The sound on the receiver hasn't really worked since. I did get it to work once via the blue-ray player again. I noticed that on the front display it doesn't list the speakers as it normally did. Perhaps that is an indication of something. I unplugged the receive for about a week and plugged back in last night and still only video. I should also note that when it worked again I could use both the blue-ray and cab/sat all night and noticed the speakers listed on the display were there. Turned in back on the next day and no speaker listing and no sound.
