I currently own what would be considered an entry-level DAC made by a local company. I compared it with the similarly priced Arcam rDAC and the former won by a small margin, I'd say that it was a matter of preference which one was better - better focus but narrower sound stage and a bit more presence. otherwise I'd say they were identical.
while I had the luck to listed to few high-end systems in the past, what I always missed were actual comparisons ("let's try this amp now and see what it does to the sound").
I know what even a $150 DAC can do to the sound compared to lesser sources (enough to quality as a "WOW" kind of difference) and since I believe that sound can be textually described to a point, I was wondering what kind of differences the higher priced DACs bring.
real, first-hand experience and examples would be much appreciated, thanks.
