So if you were to head over to monoprice and search for item 8008 you'd see the wall plates I'm using.
The HDMI part works great. It's the IR part that's giving me fits.
When I hook up the cable to a GLobal cache iTech to the sender side, and IR repeater with an eye to the receiving end, the led of the IR head that's supposed to attach to the component on the receiving end is glowing bright red the entire time rather than the occasional blinking red when it senses an IR signal.
Actually, even if nothing is plugged into the IR port on the sender side, the receiver side IR emitter head lights up red the entire time.
Needless to say, no signals get through. Not even a basic turn on/ turn off.
And I gotta say, I'm stumped.
Any thoughts?
Edited by chirpie - 11/11/12 at 3:49pm
Any thoughts?
