post #1 of 1
Hello,
I'm looking at purchasing an DVDO iScan Duo. I'll be hooking up something call a supergun for arcade gaming. More than a few of my games are vertical shooters, and some sort of a rotation will be needed.
  • Does the Duo have the ability to rotate the image?
If not...
  • Is there a video processor in the same price range with that ability?
  • Has anyone here used a low profile mount with the ability to rotate a HDTV 90 degrees?
Thanks in advance!
