My theater room is is approx 14'W & 24' deep. my ceilings are 9'. I have always dreamed of having a dedicated theater room, and I am now building that. The room is in a basement, so ambient light not an issue though the basement is a lookout and there is a window on the side wall in the back (main seating area is at 16' from projected false wall) that will have black out shades when needed. My issue is with the calculator at projectorcentral.com. Seems that anything I do is pretty much insufficient in terms of wanting to do a AT screen. I had my heart set on the Enlightor 4K screen in either 1:78 or 2:35 (still deciding. 2:35 only using zoom function for now). I want the Sony HW50ES. Problem is, at 1.0 gain (and I know this is MAX) and within the minimum throw range, I only measure at 13fl for 120" wide 2:35 (as an example). My wall is 168" wide. So this is telling me I can't even do 120". At recommended 16fl I am not even close, and even 16 fl minimum considering half life of those lamps.
The sony is extremely highly rated, as you all probably know, in that price range. What is everyone else out there doing to get these large screen sizes and getting adequate foot lamberts? Someone told me that 120" is too large given the price group I am with my projector. OK, so I tried the $12,000 JVC and no difference.
any insight would be appreciated.
