AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Basement theatre, need wiring input
post #1 of 7
Im working in my theatre build and about ready to run some wires. Im running some conduit for the wiring, what type of connections do i need to run up to the projector? Dont have the projector yet.
post #2 of 7
(My two cents...) I'd run two HDMI cables.
post #3 of 7
any point in running components anymore?
post #4 of 7
You will need a power outlet and an HDMI. I would not run a second one, but make sure you leave enough room so you can feed, string a new cable through as the cables change... we all know they will!
post #5 of 7
ill leave a string in just in case. Got power outlet within a few inches so should be good to go. Whats the point of running a second hdmi?
post #6 of 7
besides power and hdmi to the receiver.. i dont think you need anything else unless you want to run the speaker wire too. your other components can connect to the receiver directly
post #7 of 7
Run the speaker wire to the ceiling... getting ready for Dolby Atmos in the future. biggrin.gif
