AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG XXLM7200 Thread
Official LG XXLM7200 Thread - Page 25
post #721 of 731
Do the pixels go all the way to the bezel, or is there a black border around the image on the LG 60LM7200?
I have a 55LM8600 whose pixels stop 1/2" from the bezel, and a 55LM9600 whose pixels go right to the bezel.  I am making an array of these monitors, and need to minimize the black in between the images.
Thanks for any information or images you can offer.
post #722 of 731
They go to the edge of the bezel.
post #723 of 731
Thank you, Zap Branigan!
post #724 of 731
Will only a LG webcam work with this TV?
post #725 of 731
Yes
post #726 of 731
So it seems that ever since the Jan 7th 2014 firmware update my TV keeps flashing brighter and darker. Backlight problem maybe? I tried messing with backlight settings and local dimming and that doesn't help at all. Am I alone here?
post #727 of 731
I haven't had any issues.
post #728 of 731
Well, I turned the power off and unplugged the TV for a minute and the problem seems to have gone away for the time being. It had been intermittent since the update, so it my return. Hopefully, though, it will stay gone.
post #729 of 731
What was in the update..what version are you using?
post #730 of 731
06.01.03 is the version I am using. I just downloaded it this week and that's when the problem started. Since I unplugged it though, I haven't seen the issue return. I have no idea what the update was for. I tried adjusting a bunch of different settings to fix it at first. Just unplugging it should have been the first thin I tried. I do not have any power saving settings on or the ambient light sensor on so it seemed really strange that it kept dimming and getting brighter. It wasn't a gradual dimming either. It was quite jarring an obnoxious. So far so good though. We have a movie night tonight, so if the problem returns I will update.
Edited by King J Gregory - 1/11/14 at 11:58am
post #731 of 731
Ive been using that one for awhile..I suppose it didnt completley install untill after you turned the set off and then back on..you should be ok now.
