AVS › AVS Forum › Audio › Speakers › Installing a Bose system in a new house
post #1 of 11
Hi, I'm installing a new Bose system in my family's house, but the thing is that the construction crew that built the house installed the audio wiring but put in remodeling boxes so the Bose arms don't attach if I use those holes. Does anyone have any suggestions or fixes that I can do myself?
post #2 of 11
Sounds like this is your opportunity to toss the Bose stuff and get some decent speakers.
Fate works in mysterious ways.
post #3 of 11
post #4 of 11
DITTOS!!!!!!!!
I wouldn't install them in an old house!
post #5 of 11
Friends don't let friends drive drunk...or Bose for that matter.
post #6 of 11
Hey, sorry if it seams people are being harsh in regards to the Bose brand. I know most average consumers/people think Bose is a good brand. And it is actually an excellent brand.
Unfortunately it is only a brand, a marketing engine if you will. The speakers have no true reproduction of accurate sound. They rely on gimmicks and tricks to fake base and so forth. If you ever had a 1 on 1 comparison to a quality speaker you would quickly hear what a muddy mess Bose is.
Take them back, you can get much better new speakers for the same money. You can get significantly better used speakers for the same money, think Yugo vs. BMW.
Good luck!
post #7 of 11
look for some decent speakers that will work.
post #8 of 11
Wouldn't it be easy to just build a bracket that fit in the pre-made holes, then make hole in the bracket to fit your speakers. You can even paint or powder-coat the bracket to the speaker colors so they'll match. Just a suggestion.
post #9 of 11
Without knowing what model of Bose speaker you own, it is hard to understand:
1. Your problem
2. A fix
3. A suggestion for a better speaker. I use to own a Awia system that had better sounding drivers that the Bose Cinemate systemor cube speakers...
post #10 of 11
I don't know if I can help or not. First, what's a "remodeling box"? And what exactly do you mean by "Bose arms"? We definitely need a model number or at least knowledge of what type of speaker it is you are installing. In-walls or On-wall brackets for cubes or 161's? You may be best off contacting Bose.
And please accept my apology for the arrogant and condescending responses you get here when you mention the "B" word. Ignore them and maybe they'll crawl back under their rock. biggrin.gif
Edited by dat56 - 11/14/12 at 8:23am
post #11 of 11
like i said before bose makes beautiful sound, just throw a cube against a concrete wall and man what a sound. wow, just beautiful.the dynamics and soundstage where great. treble was good but lacked in the bass dept.
Edited by smasher50 - 11/14/12 at 4:20am
  Back to Forum: Speakers
