I came across this very interesting motherboard recently. I've never taken any interest in Biostar products due to the poor reviews but this one is very compelling since I don't see anyone else offering something like this (at least not for sale in the US). This is available at Newegg, Superbiiz, et. al. It has a 17W TDP Sandy-Bridge mobile Celeron processor with Intel HD Graphics. The price is well under $100.
http://www.superbiiz.com/detail.php?name=MB-NM70847
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=617
Intel celeron 847 (dual-core Sandy Bridge-MB running at 1.1GHz) and Intel nm70 chipset
• 2 x DDR3 memory slots (up to 16GB).
• 1 x SATA II port.
• 3 x SATA II ports
• 1 x PCIe 2.0 slot (x8)
• Gigabit Network (Realtek 8111F)
• 4 x USB 2.0 ports
• D-Sub (VGA) and HDMI
• 5.1 analog audio
http://www.superbiiz.com/newg/M/B/-/MB-NM70847/MB-NM70847.3_LG.JPG
http://www.superbiiz.com/newg/M/B/-/MB-NM70847/MB-NM70847.1_LG.JPG
It looks like ECS is also coming out with a Celeron 847 / Intel HD graphics mITX motherboard
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=1424&DetailName=Feature&MenuID=1&LanID=0
I was very interested to see how these Celeron 847 / Intel HD graphics mITX motherboards perform as HTPCs.
Passmark
Celeron 847 = 1016
AMD E-350 = 786
Intel Atom D2700 (2.13GHz) = 842
I ordered one to try and built a test HTPC with it.
S197-H80 case
picoPSU-90 with 60W AC adapter
4GB DDR3-1333
128GB SSD
It played 1080p flawlessly in WMP and handled Netflix HD using IE/Silverlight without any problem though with pretty high CPU usage (but at least it worked!). Windows seemed very responsive though launching programs did take a little longer than I would have liked. Overall, I was very impressed with the performance. It was much better than the Atom D2700DC I'd tested a few months ago. The biggest problem was the little 40mm fan being used for cooling. For a 17W TDP CPU/GPU I was very surprised how hot it ran, around 60C the whole time. Interesting is that the max. temp. spec'd for this is 100C so maybe it's supposed to run hot. I replaced it with a Scythe Mini Kaze 40mm and it worked much much better -- much quieter and a bit cooler.
• 1 x SATA II port.
• 3 x SATA II ports
• 4 x USB 2.0 ports
• 5.1 analog audio
Passmark
Celeron 847 = 1016
AMD E-350 = 786
S197-H80 case
4GB DDR3-1333
128GB SSD
. I also tried the 80Mbps and 120Mbps samples from here with no problem:
