AVS › AVS Forum › Video Components › Home Theater Computers › First HTPC build. Full component reviews/build pictures.
post #1 of 18
Hey guys. I am going to be documenting this build. The machine will be hooked up directly in the living room to the HDTV and will be running WMC as well as XMBC. Here is a list of the items I will be using. Please feel free to comment. There will be some pictures as well as some reviews later on as well.
Memory
Crucial Ballistix Sport 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model BLS8G3D1609DS1S00 $30
Case
Silverstone Tek Micro-ATX Mini-DTX, Mini-ITX Mini Tower Plastic with Aluminum Accent Computer Cases PS07B (Black) $80
SSD
OCZ Agility 4 AGT4-25SAT3-128G 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) $70
PSU
PC Power and Cooling Silencer MK III 600W Modular 80PLUS Bronze Power Supply compatible with Intel Sandy Bridge Core i3 i5 i7 and AMD Phenom $70
Processor
Intel Core i3-3225 Ivy Bridge 3.3GHz LGA 1155 55W Dual-Core Desktop Processor Intel HD Graphics 4000 BX80637I33225 120$
Mobo
ASRock Z77 Pro4 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard $60
Silicon Dust HD HomeRunPrime -$140
XBOX 360 as bedroom extender - TBD
2TB WD Green as additional drive for DVR
I will also be adding 3-4 additional drives depending on BF/CyberMonday deals.
post #2 of 18
reserve for build pictures.
post #3 of 18
reserved for component reviews
post #4 of 18
Well you list the case as a microATX and seem to have chosen an ATX mobo. Is that a typo or an oversight?
post #5 of 18
PSU is pointless. Get a Seasonic S12II-430, mobo is also pointless, get an H77M-D3H. You don't need gaming hardware for a HTPC.
post #6 of 18
Agree that you've chosen mATX case with ATX mobo
If you can get that board for that price, go for it. It won't hurt and it won't use any more power, but if it's more expensive then there is no use to get the z77 over h77 with a non-k i3 processor
As for the PSU, I very highly recommend the silencer MKIII, but you don't really need 600W. Each HDD you add will only run you an extra 10W, and your base config won't require more than 60-70W, so 600 is not only overkill but ineffecient. You should target 20% or 50% but never less than 20% for your PSU. Go with the 400W version, or if the case is not completely decided upon consider this one link. It comes with an Antec Green 380W PSU
post #7 of 18
Seasonic's PSU's (or Seasonic internals) are the best overall. Only Enermax can come close.
post #8 of 18
post #9 of 18
post #10 of 18
Ha! Well definitely cheaper in price, it doesn't appear to be modular, and the OP didn't exactly state a budget, so naturally I recommend what I use. smile.gif
post #11 of 18
You recommend the Corsair CX430 quite a bit. Corsair's OEM for that model is Channelwell
I thought the case I recommended came with a Seasonic made PSU branded by Antec, the EA-380. It turns out to be the EA-380D which is manufactured by Delta.
Still a good price.
I like Seasonic PSUs as well, that's why I always recommend the PC Power and Cooling Silencer MKIII biggrin.gif
post #12 of 18
You might want to look for better deals on the SSD as well. I got a 128GB Vertex 4 for $80 some months back and Black Friday should beat that price.
post #13 of 18
post #14 of 18
Still a good price.
Corsair simply because the quality is great and its really cheap, and also that Seasonic may not be available depending where you live. BUT Seasonic first and foremost. Excellent quality.
post #15 of 18
Okay, so you really mean Corsair because their quality control is great when rebranding a quality PSU actually made by Channel Well. I don't think there quality is that great, because it's too loud for my taste but it's hard to beat for $20
Since we both agree that Seasonic is a good quality PSU, maybe you should realize the following units are made by Seasonic
  • Antec Neo, Eco, Earthwatts, and High Current Gamer models <600W
  • Arctic Cooling Fusion
  • Corsair CX (400W), HX (450, 520, 620, 650), VX 450, and TX 650
  • PC Power and Cooling Silencer MKIII
  • XFX Black Edition and Core Edition
post #16 of 18
Great post!! ^
Don't forget people won't buy the PC power and cooling you have because OCZ owns them too..
I ended up grabbing a 530wat Eco neo and. 400 watt neo for 25$ and 29$ and I think it's a good little PSU for cheap.
Just remember that Antec is so cheap they don't give you a power cord ....
post #17 of 18
Originally Posted by Mfusick View Post
Great post!! ^
C'Mon man. Knock it off. You have over done it.
Btw antec isn't cheap. Its part of the "green" product line as the want you to reuse a ubiquitous power cord that you likely already own.
post #18 of 18
That's just a dumb excuse not give you a power cord IMO...
But other than that its a great choice. I have two.
