AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Audyssey MultEQ Pro
Audyssey MultEQ Pro
post #1 of 2
My question is: I've seen the mic that comes with the Audyssey Calibration Kit and was wondering if I were to use my own shotgun mic and terminate the ends to plug into my Integra DHC-80.3 Pre-Amp, will my mic work with the built in MulitEQ Pro calibration test? I don't think I need the software that comes with the calibration kit.
And if it doesn't work; instead of using the included mic that came with the pre-amp, will I still be able to use a better, higher quality and more sensitive microphone with my pre-amp and run the normal MultiEQ XT 32?
post #2 of 2
The one with the calibration kit it not flat, bu the software is tuned for it. Don't replace.
