All,
There are enough posts on the forum of owners with older JVC projectors (RS1, RS2, RS20, RS10) who experience a stripe, usually pink, down one side of their projector due to a fault in the optical block, that indicates that this a reasonably regular fault with these projectors. Its not exactly clear what causes this and the fix is to replace the optical block at a cost higher than the resale of these projectors, and the fault can occur with as little as 1000 hours and for a lot of us it has happened after the warranty period has expired. I have a yellow stripe on the right hand side of the screen which developed at 1200 hours in a well ventilated position without having the projector on for a long period of time where it could overheat.
Although it could be argued that an expensive piece of consumer equipment should last longer than 1200 or so hours, it is out of warranty so I'm stuck. It is possible to mask off the fault but that isn't a proper fix and you lose some of the image. As I have had almost 4 good years with this projector, which otherwise throws a very fine picture, I'll suck it up and move onto the newer model with more shiny bits (3D, e-shift etc.).
Apart from this fault I really like the JVC projectors and am on the preorder list for a new one. However I'm wary of getting another JVC projector if this fault is also evident in the newer JVCs, especially if it shows up after the warranty expires if you don't use the projector regularly. So coming to the reason for this thread - do any JVC projector owners with this year or last year models experienced this (or similar) problems? I'm aware that it will only show up in recent models with higher than average usage, but there should be enough end users with enough hours on their projector that this problem should start showing up by now.
Please post back if you know if this problem has been resolved or if you had a recent JVC projector which exhibited the problem. Thanks.
