Originally Posted by
ap1
You can't get what you want cheap. The only option to get high resolution stereo through spdif is to buy one of Oppo players and then digital output interface for it (which requires you to have some skills to install it). But total cost will be in range $800-1000.
Not the only option. Pioneer BDPs output 2CH DSD as 2CH PCM 88.2kHz via optical. You cannot pass DSD via SPDIF: the spec itself does not support it. My Pioneer 140 only costs me a little over $100: the cheapest that I know of to pair with ext. 2CH DACs.
Get a modded Oppo ($1500)
Get 3 x wyred 4 sound DAC2 ($4500)
Get a good SSP for less critical sources (satellite TV) (Marants / Onkyo?) ($2000)
Good digital cabling (essential! $1000-$2000)
source)
This might do better and you get MCH.
But the cost of better DACs could lead you down the spiral...
If you have more to spend, replace the wyred 4 sound DACs with Bel Canto DACs...
(same source as above)
A stereo DAC that sounds as good as what is built-in to the stereo outputs of the DX-5 is probably going to cost at least $5,000 to $10,000. And you need four of them. So your $400 modification is up to somewhere between $20,000 and $40,000.
source)
