I assembled my HTPC this weekend. It is very fast and boots to windows 8 in just over 5 seconds. However when I assembled the PC I noticed that the stock CPU fan/heat sink that came witht Intel Core i5-3570K is like 1mm directly below my power supply. It is almost resting on it. I have also noticed that the CPU runs at about 45-50C, which I feel is hot. I was wondering if something can recommend a good low-profile CPU fan heat sink so I can give my fan some breathing room from the power supply.
AVS › AVS Forum › Video Components › Home Theater Computers › Recommend Low Profile, CPU Fan Heat Sink
AVS Top Picks
post #2 of 61
11/13/12 at 7:25am
post #3 of 61
11/13/12 at 7:59am
post #4 of 61
11/13/12 at 9:44am
post #6 of 61
11/13/12 at 10:29am
post #8 of 61
11/13/12 at 11:20am
post #10 of 61
11/13/12 at 11:35am
post #11 of 61
11/13/12 at 11:56am
post #12 of 61
11/13/12 at 4:03pm
post #13 of 61
11/13/12 at 6:03pm
post #15 of 61
11/13/12 at 6:33pm
post #17 of 61
11/13/12 at 7:33pm
post #18 of 61
11/13/12 at 7:45pm
post #20 of 61
11/14/12 at 5:02am
post #22 of 61
11/14/12 at 5:45am
post #24 of 61
11/14/12 at 6:58am
post #26 of 61
11/14/12 at 9:29am
post #29 of 61
11/14/12 at 10:09am
AVS Top Picks
). Then the only reasonable solution (except that you replace the case with a bigger one) may be replace the stock PSU with picoPSU-160-XT + a 150W AC-DC adapter and use a bigger, more powerful CPU cooler such as Cooler Master GeminII S524 (that should fit your mb).
