AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › ST50 Can't connect to Viera Server
post #1 of 5
Hey all,
Sorry to start a new thread but I posted this on the ST50 Owner's thread and didn't receive a response and didn't find anything from a search either.
My 50ST50 connects to my wifi just fine but it has never been able to connect to the VIERA server. If you do the connection test, it passes all the tests quickly until it reaches the final test, connecting to the VIERA server, at which point it takes a while and ultimately fails. As such, I've never been able to use any of the smart TV functionality. Any help on this?
post #2 of 5
Same problem with my 55ST50. I did a firmware update and since then nothing outside the home network works.
post #3 of 5
I am wired and just connected with no issues. Firmware 1230-1030. 60ST50.
post #4 of 5
Firmware 1190-1030. Wired doesn't work either.
post #5 of 5
I cant connect either.
