So I've been running two 685 bookshelf speakers, as well as the HTM62 center channel on my SC-25 for a few years. I noticed a slight distortion on the center channel during loud volumes, and have since attempted to correct this by changing the speaker setting inside the SC-25 menu from "Large" to "Small" - and as far as I can tell, everything has improved.
However, before I did this, I wrote Pioneer asking for technical support, and they needed my speakers impedance and power ratings. When I responded to them with information such as this: "Nominal impedance 8Ω (minimum 3.7Ω)" (685), and "Nominal impedance 8Ω (minimum 4.3Ω)" (HTM62) - they responded back saying that my speakers are "incompatible" with the Pioneer AVR because they fluctuate between 3.7 (in the case of the 685 speakers) and 4.3 (HTM62) to 8ohms.
They are saying when my Pioneer is pushing loud volumes, the speakers are closer to 4ohms than 8, and that by doing so, I may damage the SC-25 receiver, and again, my speakers are "incompatible" with this receiver.
Can anyone else shed some light on this, or reassure me that this is actually OK? I spent A LOT of money on my 3-channel system just for peace of mind if nothing else, and now it turns out I don't even have that! What's the deal??!!!
